fuzz |
fuzz World Chat Champion
Posted: 20:29 - 19 Oct 2005 Post subject: Fitting an immobiliser |
I have bought an Acumen 911 alarm and immobiliser for my SV650S, but I'm a little unsure of how to fit the immobiliser. It says to cut the wire from the starter switch to the solenoid. Which solenoid are they talking about? I've looked at the wiring diagram, and the switch is connected to the HT coils on one end (I'm not cutting either of them!) and the starter control relay via the clutch switch. I assume you cut the wire somewhere between the clutch switch and the starter control relay? ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
sickpup |
sickpup Old Timer
BFG |
BFG Brolly Dolly
fuzz |
Posted: 20:57 - 19 Oct 2005 Post subject: |
I think the idea is to stop it being hot-wired. If it was connected to the ignition system and it malfunctioned when riding it could cause an accident.
Second question would be where could I connect the +ve terminal to so that it's only live when the ignition is on? One place I can see is the wire to the fusebox from the ignition switch (fuse #3 in the diagram below.)
https://www.sv650.org/ig_retard/Wiring_Diagram.jpg
I'll try and post a full diagram later. ____________________ https://www.bikepics.com/members/fuzzbcf/
sickpup |
sickpup Old Timer
BFG |
BFG Brolly Dolly
fuzz |
BFG |
BFG Brolly Dolly
Posted: 22:19 - 19 Oct 2005 Post subject: |
Ahh - that's only one half of the diagram isn't it?
Thought there was loads of stuff missing
I was going to say O/Y was a good bet for the + feed, as you say on relay #3, but need the rest of the diagram to be 100% sure. |
sickpup |
sickpup Old Timer
Posted: 22:21 - 19 Oct 2005 Post subject: |
BFG wrote: |
Honestly, don't waste your time - preventing the starter from turning is pitifully easy to bypass. Yes.
Unless it's a scooter anyone could bump start it in seconds. And if it's a Goldwing all you have to do is run any bit of copper wire lead from the + battery terminal (or any + supply lead, easy to find) to the start motor and it'll start. Doddle. No you have to do a bit my than that like bypass the ignition or you get no spark and in the case of a bike with a fuel pump no fuel
You need to prevent the engine from running.
If your immobiliser has normally open switching as well as normally closed, consider using the kill-switch circuit (somehow missing from the circuit diagram). What this does is short the ignition coil to earth 100%, meaning the bike can never start and it can not be bypassed by running extra wires. Also you don't even need to cut the wire - just join to it. Most bike electrics dont work this way anymore. If they did all you would have to do to start a bike is smash the kill switch and bump start
If you have to cut a wire and use normally open switching, do it to one coil only. Safer in event of failure in normal riding, and causes thief to make lots of noise and not get anywhere - and maybe even give up thinking bike is knackered. The best way is to immobilise the starter circuit and then a secondary circuit like the fuel pump. If this is done to thatcham standards it works well. |
sickpup |
sickpup Old Timer
BFG |
BFG Brolly Dolly
fuzz |
sickpup |
sickpup Old Timer
sickpup |
sickpup Old Timer
fuzz |
Posted: 00:58 - 20 Oct 2005 Post subject: |
That's why it was cheap though. I basically got the immobiliser for free anyway, so I'm not too bothered. If it makes a noise and keeps people busy a little longer than usual it's about as much as I can ask for given the money. ____________________ https://www.bikepics.com/members/fuzzbcf/
sickpup |
sickpup Old Timer
The last post was made 18 years, 195 days ago. Instead of replying here, would creating a new thread be more useful? |
