Decent headlight for winter?
alfie698
PostPosted: 15:14 - 20 Oct 2005    Post subject: Decent headlight for winter? Reply with quote
I've got a Honda NTV650 with a rather poxy "Stanley" (whoever they are! Thinking ) H4 headlight. The headlight gives off a nice warm glow on dipped beam, but I commute down some country roads and it would be nice to see where I was going now that the nights are drawing in. The bike has a Powerbronze fairing fitted, so I cant change from the standard round light (that and part of the wiring loom is in the back of the light).
Does anyone have any ideas / experience with better lamp units or other H4 bulbs that would actually light up the road?
Alfie
Ted: "These are small; the ones out there are far away."
Dougal: "I still dont get it, Ted."
https://www.bikepics.com/members/alfie698
sickpup
Old Timer
PostPosted: 18:26 - 20 Oct 2005    Post subject: Reply with quote
If you have the standard headlight with a Halogen (black tip) 55/60W bulb it should be bright enough. You may need to clean the lens or adjust the angle of the headlight.
PostPosted: 19:36 - 20 Oct 2005    Post subject: Reply with quote
If you are still stuck. M&P do CIBIE sealed beam inserts to fit inside a standard round headlamp shell.
binge
Emo Kiddy
PostPosted: 00:22 - 21 Oct 2005    Post subject: Reply with quote
https://data.solidcactus.com/cjimages/autobarn/opelblufogli.gif
All you need is some wire, A switch and a few nuts and bolts!
Bright light! Cool
PostPosted: 01:10 - 21 Oct 2005    Post subject: Reply with quote
If those are the same ones I got, they are pish. They take a crappy H3 bulb and have a very diffuse pattern. The output is improved by removing a baffle plate from inside the lens but still not good enough to see by in the dark. They appear bright when you look at them and are helpful for penetrating fog/mist as an accessory lamp but as a main light source they are useless.
The last post was made 20 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.97 - MySQL Queries: 14 - Page Size: 44.44 Kb
