| White Noise |
 White Noise Mr Dudwee
 Posted: 20:40 - 19 Oct 2005 Post subject: Front end setup |
got my forks back from the garage today and fitted the front end back on the bike this evening, but to get the wheel back on the forks i had to jack the bike higher than i did when i took the wheel off. the forks are at the right position at the top of the yokes but seem to be hanging down more than they where when unloaded. is this the result of having the correct amount of oil in now? reassembled incorrectly? or a simple case of the trolley jack the bike is resting on slowly colapsing under the wieght of the bike?
anyway as a result i recon the bike is going to feel a hell of a lot different when i come to ride it, if its due to more fork oil, so just wondering if anyone can give me any tips for setting up the front end.
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| tatters |
 tatters Exxon Valdez
 Posted: 21:32 - 19 Oct 2005 Post subject: |
Just keep the forks on there manufactors settings as qoute in the workshop manual if you,ve got one (l think they work them out for a 75kg person), from my experances with adjustable forks its best not to mess with them.
My thunderace felt alot higher with fresh fork oil, l did have ago with ajusting the spring preload and both damping ajusters on each fork but never could get the bike to feel right so went back to the manufactors settings. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| DucatiEVO |
 DucatiEVO Could Be A Chat Bot
| White Noise |
 Posted: 22:49 - 19 Oct 2005 Post subject: |
just had the fork and dust seals done, one seal was leaking pretty badly so figure lost a lot of fluid then
| DucatiEVO |
 Posted: 22:55 - 19 Oct 2005 Post subject: |
Check your calipers too, normally when a fork seal leaks badly, the fluid runs down the fork to the caliper and gets on the brake pads. Quick squirt with a degreaser will sort it.
 ____________________ aKa: Ducky |
| White Noise |
 Posted: 23:32 - 19 Oct 2005 Post subject: |
just overhauled them so should be fine, but cheers
| White Noise |
| Gazdaman |
 Gazdaman I did a trackday!!!
The last post was made 20 years, 304 days ago. Instead of replying here, would creating a new thread be more useful? |
