Cog Head |
Cog Head Could Be A Chat Bot
Posted: 01:00 - 24 Oct 2005 Post subject: sumfing it seriously rong with my bike :O |
my break light is permently on, the high beam isnt very high, my battery dosnt charge properly wen i ride, the fule mix is too rich as my m8 says bit its an auto mix 2 stroke, can any one help me here ? ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore
McGee: Hence I smell like a gimp |
18_stuart_88 |
18_stuart_88 World Chat Champion
Posted: 01:07 - 24 Oct 2005 Post subject: |
Ive got a suggestion about your break light being on permanently but not for the rest
Have your tried taking out your bulb and re-fitting it. I had that small problem when i was striping my bike to put a new left hand side on it
Fixed itself after re-fitting
Stu ____________________ Make: Honda NSR 125 R Year: 2004 Colour: Black And Silver - Died on December 18th 2005, Layed to rest December 30th 2005 :(Make: Aprilia RS 125 Year: 2000 Colour: Black And Red - Derestricted Sold!
Make: Suzuki GSXR 600 SRAD Year: 1998 Colour: Red - White - Blue
Pic of My New Bike!! |
Cog Head |
Posted: 13:08 - 24 Oct 2005 Post subject: |
its a Rieju RS2 50cc MATRIX Race Replica ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
muddycoffee |
muddycoffee Nitrous Nuisance
Posted: 15:35 - 24 Oct 2005 Post subject: |
One of your brake light switches is probably sticking on. On scooters they are usually cylinder shaped and screw into the mounting that the lever is mounted on. They operate when you press the lever which alows the plunger to move out and operates the switch.
What I would do is first isolate which one is at fault by disconnecting the wires from them one at a time, when you disconnect the faulty one, the light should go out. unscrew the switch and spray it with loads of WD40 then work the plunger in and out. If this doesn't work, you may need to replace it.
This could also explain the dim headlamp, certainly on my mopeds, operating the brake light took power away from the headlamp and made it appear dim. Could also be that your battery is duff.
Check that the headlamp gets brighter as you rev up from tickover. Failure to do so can point to a problem with the charging system.
Your brake light switch most probably looks something like this:
https://mywebpages.comcast.net/gtopercy/ebay/brakeswitch.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Cog Head |
Posted: 15:58 - 24 Oct 2005 Post subject: |
ryty then i shall av a go at dat then, but dose any one know how to stop my fule & oil mix being so rich cus there is loads of black stuff on my exhaust but iot is auto mix... ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
Mr.Everready |
Mr.Everready World Chat Champion
Cog Head |
Posted: 16:26 - 24 Oct 2005 Post subject: |
i diddnt no...y ? lol
ow yeah and my mysterious real light problem has parcially solved itself, the light stays on wen the lights r on as norm and when i put the back break on it goes brighter, but the front break lever dosent make it go brighter...confusing... ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
Mr.Everready |
Posted: 16:53 - 24 Oct 2005 Post subject: |
If the light goes on when you use the pedal but not the lever then there's something wrong with the connection from the lever then. ____________________ the undemocratically unelected mod of the Scottish section |
ZRX61 |
ZRX61 Victor Meldrew
Cog Head |
Posted: 17:31 - 24 Oct 2005 Post subject: |
shut up u muppet i was in a hurry wen i typed that up
ill get my dad to have a look at the connections later, he should know what to do...i hope...hes an electrician ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
BFG |
BFG Brolly Dolly
Posted: 18:33 - 24 Oct 2005 Post subject: |
Cog Head wrote: | ryty then i shall av a go at dat then, but dose any one know how to stop my fule & oil mix being so rich cus there is loads of black stuff on my exhaust but iot is auto mix... |
Please do try with the typing, it makes things much easier to understand and other people are then much more inclined to help you.
The oil is mixed into the fuel by a small pump somewhere on the bike. The amount of oil this pump puts out is varied by the throttle position via a cable. If the cable was too tight, this could cause too much oil in the mix. There will be marks on the oil pump that you line up to set the tension in the cable. Do not mess with them unless you know what you are doing, if you land up running it too lean, you will knacker your engine.
Running 'rich' is not always due to the oil content of the fuel mix, it can also mean the fuel:air mix has too much fuel/not enough air in it. For example, due to a blocked air filter or the choke sticking on. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Cog Head |
Posted: 23:29 - 24 Oct 2005 Post subject: |
ow right.... this gives me an excuse to but a new air filter and ill have a "look" at the oil pump and see what its set to, in my users manual it says that there might be a carbon buildup on the exhaust outlet or inside of my exhaust, i can probebly get it out of the outlet but how would i get it out of the exhaust ? ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
Posted: 02:14 - 25 Oct 2005 Post subject: |
You would usually take the exhaust off and fill it with caustic soda solution to remove excessive coking. The technique has already been discussed repeatedly if you do a search.
Caustic soda also dissolves alloy, paint, skin and eyeballs with frightening speed, beware of this before you mess with the stuff. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
mchaggis |
mchaggis World Chat Champion
Posted: 02:23 - 25 Oct 2005 Post subject: |
The air filter may well just be a foam one, hand washable with a detergent. Oil it while it's still wet afterwards, this helps distribute the oil throughout the foam as it tends to emulsify. Don't wring the foam or use overly hot water, the glue holding various layers/ parts together doesn't like it.
Depending on what bike it is, the exhaust might be blowing straight out back onto the pipe/ expansion chamber. It'll be sooty and smokey as standard, so it'll coat the pipe in crap in fairly short order. My brothers scooter was dumping oil into the engine as the oil valve wasn't always closing properly when he turned it off. A sticky throttle cable could be the culprit for that. Copious amounts of smoke and leaving black oily trails behind him were the obvious signs until it got properly warmed up.
Brake light switches, stiff mucky springs, sticky cables etc are almost always fixed by copious quantities of WD40.
Edit: if you believe in health and safety as much as I do, you'll be very interested to know how fun the reaction between a capful of caustic soda and a little boiling water can be.
I believe in common sense, sensible precautions and foresight, not health and safety. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush. |
ZRX61 |
Finglonga |
Finglonga World Chat Champion
Cog Head |
Posted: 22:01 - 25 Oct 2005 Post subject: |
wahoo yeah and this helps me fix the problems because..... ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
ZRX61 |
BFG |
BFG Brolly Dolly
The last post was made 18 years, 188 days ago. Instead of replying here, would creating a new thread be more useful? |
