throttle cables on an NSR
theshmoo
Bottomless Pit
PostPosted: 23:09 - 03 Nov 2005    Post subject: throttle cables on an NSR Reply with quote
the cable splits in to to bits the bit that has snaped is at the top on the yoke. so dose this single bit only need replaced or the hole lot. can the cable be separated at the junction/spliter joint under the fuel tank ?
CBR 1100 blackbird.
alains
PostPosted: 12:30 - 04 Nov 2005    Post subject: Reply with quote
no , you need to change all the bits . from your right handle the cable goes to a relay , where 2 cables starts : 1 goes to the throttle , the other to the oil pump . call 01728 833 020 ask TIM and order it
honda reference 17910 KBS 900 , price £24 ish
when you've changed it , set the oil pump 1mm over the notches , then after 5 hours of use , set the pump as normal . this will avoid any variation in adjustment with new cable . also set the throttle entry with 1mm play .
theshmoo
Bottomless Pit
PostPosted: 00:10 - 06 Nov 2005    Post subject: Reply with quote
thanks mate Thumbs Up
CBR 1100 blackbird.
The last post was made 20 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.37 - MySQL Queries: 16 - Page Size: 36.16 Kb
