 JonT Crazy Courier
 the grim reaper World Chat Champion
 Posted: 16:03 - 08 Nov 2005 Post subject: |
The squeal could be caused by a missing anti-rattle spring (presses down on the pads) or a dry piston against the back of the brake pads (try a little copper grease on the back (!!!!) of the pads, where the piston touches).
If it is more likely to lock up, this is normally a binding brake, causing greater heat build-up that then makes the back brake more effective, briefly. Then the normal situation is that the disc warps because of the heat.
I'd go for a full caliper strip-down, followed by a bit of copper grease on the back of the pads. Also check that the anti-rattle plate is still there.
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
