Choke cable for '97 Bandit
LustyLew
PostPosted: 23:27 - 14 Nov 2005    Post subject: Choke cable for '97 Bandit Reply with quote
My choke cable seems to have got itself jammed. it no longer adjusts but the cable has not snapped. I am guessing it has seized in the cable sleeve somewhere, so time to replace.
Is this easy to do, or will I need to drain and remove the petrol tank?
Ta for your help Smile
Bezzer
PostPosted: 23:59 - 14 Nov 2005    Post subject: Reply with quote
Runs under the tank, so you have to take it off to get the right run for the cable but don't have to drain it. Just leave the tap on ON setting then remove the tap handle(otherwise it fouls on the frame), take the back bolts out, tilt the tank up from the back and you can then disconnect the fuel guage connector and the fuel/vacuum/breather hoses
***just remember which ones go where*** it will then come off.
Put the new cable on following the route the old one takes with no kinks and connect it both ends.
But before you do all that is the actual choke mechanism on the carbs OK and not causing the problem?. You can see the end of the choke rod on the left side of the carb bank - the small diameter brass rod that connect to a bar- that moves outwards when you put the choke on, try to pull it outwards with a pair of pliers on the end of it to see if it's stuck or free.
The last post was made 21 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.79 - MySQL Queries: 14 - Page Size: 31.91 Kb
