 gardner.jake Derestricted Danger
 bidman Crazy Courier
 Posted: 19:48 - 23 Nov 2005 Post subject: |
any garage should do it for you unless their strict on making sure you are legal, if so go to a car garage with teh side casing off and just ask them to undo the variator nut, slide off the washer an then tighten it up also your performance exhaust will have a restriction funnel in the end this will have to be drilled or cut out for it to perform at its best hope this helps, Dan  ____________________ Don't ride it, RAG IT!! |
 Biker-Kev Brolly Dolly
 Posted: 22:31 - 23 Nov 2005 Post subject: |
If you are 16, a garage prob wont de-restrict it for you so best to get your old man to take it in for you. Failing that do a search on derestricting 50cc and you could do it your self. As BIDMAN says the funnel must be removed. ____________________ Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
https://www.bikepics.com/members/bikerkev/
Theory: Passed 8/11/2005 Practical: Passed 13/12/2005 Proud holder of A2 license |
