Bendy |
Bendy Mrs Sensible
Posted: 17:51 - 03 Dec 2005 Post subject: Started taking the CBR apart today. |
For those who don't know, I binned my bike at Brands Hatch about two weeks ago. I put off doing anything with it due to it being very cold in the garage and my left hand being pretty useless, but that's getting better so I made a start today.
This is what she looked like before I started:
https://www.evilbendy.co.uk/gallery/albums/brandzzz/normal_PICT0020.jpg
First things first, getting the tail fairing off. It had broken all the way round and I only had to undo one screw for a big chunk to fall to the floor. Other than that, damage is pretty minimal - I need to liberate the tail light and some little screwey things and then I might have a go at plastic welding it just for the experience.
https://www.evilbendy.co.uk/gallery/albums/crashedcbr/normal_PICT0009.JPG
Get the can off so I can have a closer look, alas it does appear to have a big crack in the carbon. I'll try it on the bike and see if it's blowing or not (suspect it will be) but to be honest, it cost me £25 and has done me a year so it'll be no great loss if it's buggered. Still got the standard can so that can go back on until I get a new race can.
https://www.evilbendy.co.uk/gallery/albums/crashedcbr/normal_PICT0008.JPG
(You can see the crack above the 'ON' and then down a bit.)
Brake pedal's a tad bent but I don't appear to have broken the peg hanger.
https://www.evilbendy.co.uk/gallery/albums/crashedcbr/normal_PICT0007.JPG
Cleaned all the mud off the tank and while it's not dented, it's got rather worse gravel rash than I'd hoped.
https://www.evilbendy.co.uk/gallery/albums/crashedcbr/normal_PICT0004.JPG
The right hand side fairing was mashed enough that I was able to remove it without removing the bend crash mushroom (I did clobber it several times with a pair of pliers though). The big hole where the mounting point would be wasn't actually anything to do with this crash, or indeed my Silverstone one last year - that's all the work of the previous owner. You can't see the hole when the mushroom is on, and the piece of fairing is firmly attached to my previous mushroom. Anyway, no worries about this panel, I have an almost mint one under my bed. Might weld up the crack in this one and use it, might just hang it on my trophy wall.
https://www.evilbendy.co.uk/gallery/albums/crashedcbr/normal_PICT0010.JPG
On to the front end. There's an impressive scrape along the top of the brake reservoir and the H frame is slightly bent. The 'dashboard' plastics aren't as bad as I thought they were, more displaced than broken. Should be fine when bent back into position but that'll have to wait.
https://www.evilbendy.co.uk/gallery/albums/crashedcbr/normal_PICT0005.JPG
There's a hefty chunk missing from the top fairing but I can happily ignore that. The little bit that's broken off with the screen will be fine to glue back in place, the new screen will hold it. Don't seem to have bent the bars or done any damage to the forks, which rules.
https://www.evilbendy.co.uk/gallery/albums/crashedcbr/normal_PICT0003.JPG
Mudguard's trashed and I couldn't get it off as the LHS bolt requires left hand up the inside of the mudguard action and that hurt. So it can just dangle there for a while. All that grass and mud you see lying on the ground came from my RHS ram air pipe, the turf was wedged up there further than my longest screwdriver would poke so I pulled out the ram air tube and walloped it a lot. There was also a hefty amount stuck to the radiator, most of which I chiselled off.
https://www.evilbendy.co.uk/gallery/albums/crashedcbr/normal_PICT0001.JPG
So, the main task really is bending the H frame back which requires a big strong boy or a length of scaffolding pipe. Or both. Crash mushroom needs smacking with a hammer and a new bolt. Ram air needs hoovering out and the air filter's probably full of bits - another two handed job I'm not going to attempt yet. And of course, a good going over with a pressure washer.
I've got a new RHS panel, spare tail fairing and the standard screen and can to go on so as soon as that H frame's fixed she should be back on the road - don't seem to have cracked or bent anything important, which is a result. Tis due a major service anyway so I'll probably see about that before concerning myself too much with cosmetics.
No real point to this, just thought I'd write it up. |
McGee |
McGee O RLY?
Andy C |
Andy C Tree Seeking Missile
MarJay |
MarJay But it's British!
Posted: 18:35 - 03 Dec 2005 Post subject: |
Interesting write-up Bend, cheers! ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
distortion |
distortion Nearly there...
Posted: 19:36 - 03 Dec 2005 Post subject: |
Better than i thought it would be. Remember reading peoples write up's about it and thought
Glad there aint too much damage / work to be done Bendy.
Let us know how you get on with her
JP |
jonnay |
jonnay World Chat Champion
Posted: 21:20 - 03 Dec 2005 Post subject: |
First I'd heard about the crash, bet you were gutted, that was a really nice looking bike Glad to hear you're able to get it back to how it was though
Those H frames bend rather easily, don't they? I had to have a new one after a 5mph "drop" in that car incident, I couldn't even see it was bent until after the insurance company had given me a new one, and the old one was removed from the bike. It's pretty twisted.
Best of luck with the rest of the project, hope you have it ready for the nicer weather next year
Jon ____________________ ::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi:: |
Irezumi aka Reuben |
Irezumi aka Reuben Carrot Top
Bendy |
Bendy Mrs Sensible
Posted: 21:37 - 03 Dec 2005 Post subject: |
To be honest, that exhaust was too loud (if rather gorgeous), so I've got an excuse to get myself a replacement now.
Tis fine for trackdays but it made me go deaf in Scotland and makes me wince when I ride through a sleepy village or past a policeman. |
NC30UK |
NC30UK Scooby Slapper
McGee |
McGee O RLY?
Robby |
Robby Dirty Old Man
Villers |
Villers World Chat Champion
Posted: 02:01 - 04 Dec 2005 Post subject: |
Having crashed an FX myself bendy I now know how crap the honda fairng bolts etc are, they just tend to spin in there holes when you really want them to bite!
Its a shame to see so much damage but it looks mostly cosmetic and the main part of the bike (you!) appears to be fine!
Good luck wioth the project!
____________________ RS125 > CBR6 > SV650S > ZX636R > GSX1300RZ Hayabusa > 06 RSVR Mille ≥ Sv1000s somehow
'You came on your own, thats how you'll leave' |
Bendy |
Bendy Mrs Sensible
Posted: 17:35 - 20 Feb 2006 Post subject: |
Alright, update time.
What with moving house and it being soo cold over winter, the bike's been ignored for quite some time. This week, back down to business...
- Got the broken mudguard off completely using Luke's not-broken hand.
- Top fairing off, spent an evening lovingly rubbing 'T-Cut Colour Wax' into it so it looks a bit better.
- Robby round to help - got the K&N (with free Huge Moth) out, cleaned and oiled. Hoovered out the airbox and washed all the mud out of the ram air tubes.
- Front subframe bent back into position as best we could. Top fairing back on, new screen (cheesey 'Moto GP' one!) fitted. It all lines up well enough, I'll be leaving the 'dashboard' plastics off though as they make it obvious that everything's on a little bit of a wonk.
- U shaped brake pedal replaced with straight one from my spares box.
- Tail fairing changed for a shiny black one from eBay, mudguard replaced with yellow one. Tis supposed to be the other way round, as standard.
- Battery is dead as a dead dodo. Got a spare from G but Luke's hogging the charger at the moment - hopefully later in the week she'll live!
Got myself a full Micron system on ebay last month but I'm leaving that until I can get some dyno time booked, going to get the bike serviced before I do that. New crash mushroom that Swaffs got me is MIA somewhere in G's house, so no side fairings til that's found (or I buy one myself).
Trackday season starts soon. |
Robby |
Robby Dirty Old Man
veeeffarr |
veeeffarr Super Spammer
MarJay |
Posted: 18:12 - 20 Feb 2006 Post subject: |
You look quite a bit like Mendoza too... ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
numark1 |
numark1 Scared of girls
Posted: 18:53 - 20 Feb 2006 Post subject: |
Robby looks like a normal person. |
veeeffarr |
MarJay |
Posted: 20:32 - 20 Feb 2006 Post subject: |
Caption:
Come Here Mr Jefferson, I have something for you! ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
msgander |
msgander Brolly Dolly
Posted: 21:43 - 20 Feb 2006 Post subject: |
thats good news bend, glad to hear the new workshop is in progress!! ____________________ Always believe that your guardian angel flies a bit faster than you............... |
riichy |
riichy World Chat Champion
Posted: 00:13 - 21 Feb 2006 Post subject: |
new plastics,, and a bit of bending and it will be good as new .............good lick ____________________ .......... PLOD ............ zx636 2004 |
anders |
anders Banned
Posted: 03:16 - 21 Feb 2006 Post subject: |
Nasty one, glad you are okay though, take it easy and have fun re-building it, will be fun, make it look good though, I have seen bad jobs before, don't make that mistake make it look nice please.
Relax get better ____________________ Call me Mr. Blobby |
Parmo Paul |
Parmo Paul Crazy Courier
Posted: 03:48 - 21 Feb 2006 Post subject: |
So is this the cause of falling numbers of common British Moths.... CBR air filters?
Look here if my humour needs to be explained, it usually does ____________________ paul. |
anders |
anders Banned
kev |
kev I Hump Things
Posted: 22:07 - 11 Mar 2006 Post subject: |
If you need any help or anything welded you know where i am. ____________________ 20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes |
The last post was made 18 years, 48 days ago. Instead of replying here, would creating a new thread be more useful? |
