Kram |
Kram World Chat Champion
the grim reaper |
the grim reaper World Chat Champion
Posted: 10:53 - 14 Dec 2005 Post subject: |
You say that the battery voltage is about 14.4V at idle? That sounds high to me. What does the voltage go to when you rev it? If it's above 14.5V it's cooking the battery, that could be a reg/rec problem or an alternator problem.
If it doesn't, my guess is that you have more than one problem. If it cuts only one cylinder at 6k, I'd say spark plug/HT lead, if it actually cuts two, I'd say coil.
The idle voltages with lights on etc are fine, as long as the battery is above 12V then the relays will switch OK. I'd say that the idle problem is possibly down to the coil drawing more current than it should, difficult to say.
I'd replace the spark plugs as a check as it's cheap and easy to do. Then I'd start looking at the coils and HT leads.
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
Kram |
the grim reaper |
Posted: 11:00 - 14 Dec 2005 Post subject: |
I could give you a hand if you fancy a ride to the New Forest at any point. Send me a PM if so, I'm a leccy Engineer by trade so I should be able to help
Kram |
The last post was made 18 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
