| Author |
| shammon |
 shammon World Chat Champion
| Back to top |
| Kickstart |
 Kickstart The Oracle
| Back to top |
| Finglonga |
 Finglonga World Chat Champion
| Back to top |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 14:35 - 01 Jan 2006 Post subject: |
A vibrating engine problem on my Mum's CG turned out to be a combination of a knackered front sprocket and piston slap. A new sprocket, new piston and honed bore fixed it. The first bit is simple to sort out to see, the latter would be a little more expensive.
A knackered front sprocket wouldn't necessarily being doing the hop, skip and jump if you aren't putting a drive torque through it (i.e. if you have the clutch in). Check it to make sure it hasn't got hooked teeth, and check the chain to make sure it hasn't got stiff links. As it's a split link jobby, it's simple to take it off to clean/ lube it properly. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| Back to top |
| shammon |
 Posted: 22:39 - 01 Jan 2006 Post subject: |
Well i ended up today getting dirty, With the bike You were spot on,.... the front spocket was wobbling! so worn on the outer and inner cog fixture, will have to wait for the parts to come but i hope thats the prob. engine runs fine. Also removed the rear cog and checked the rubber bushed which were ok. il get a piccy for others to see. ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
| Back to top |
| shammon |
 Posted: 23:22 - 05 Jan 2006 Post subject: |
fitted new spockets and chain, and the Bas*ard still is vibrating but not as bad as before. checked all over and it appears there is still some slight movement side to side on the front sprocket I did not replace the front sprocket bracket which retains the sprocket onto the drive shaft. so will have to try this before i give it a kicking.
My fear is the drive shaft raised points which stop the sprocket comming of could be worn due to the previous one? and therfore with me fitting the new one it will stil have play. heres a pic of the sprockets for any one intrested with a cg.
https://i7.photobucket.com/albums/y277/shammon/mini-DSC05024.jpg ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
| Back to top |
| veeeffarr |
 veeeffarr Super Spammer
| Back to top |
| Kickstart |
| Back to top |
| veeeffarr |
| Back to top |
| shammon |
 Posted: 10:18 - 06 Jan 2006 Post subject: |
Thanks Keith & Toby il have a check today for possible snapped bolts  ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
| Back to top |
| shammon |
 Posted: 11:45 - 07 Jan 2006 Post subject: |
Thanks Toby it was the bolt you spoke about, It was not snapped but loose enough to causethe engine to move and vibrate bad. The bike rides so much better and the gear change is more smooth.
Thanks to all  ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
| Back to top |
The last post was made 20 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
