| Author |
| robboadd |
 robboadd Nitrous Nuisance
| Back to top |
| satans_BIG_helper |
 satans_BIG_helper Nearly there...
 Posted: 21:29 - 05 Jan 2006 Post subject: |
Lack of 2T oil possibly did you run the bike in ie run it gently for a few hundred miles or just thrash it straight off
Most likely lack of 2 stroke oil tho.... maybe the pump is not adjusted properly or its not been bled properly after the rebuild... ____________________ TS 50er >CG 125>AR 125>TZR250> z200(shit heap)> ZXR750 H2 > VT500 FT >XLR250 > Mito125mk1 (unlucky strike) > TZR250 3ma > GS550 > TDR250 > GSXR750 >GS1000 > Elefant 650 > GPZ750 > FZR600>z1000 (03) > KTM 640 LC4
(Yeah i forgot some too :S ) |
| Back to top |
| robboadd |
 Posted: 22:09 - 05 Jan 2006 Post subject: |
Nope I ran it in properly only took it over 7500rpm a couple of times.
I thought it may have been because the piston was hitting the head gasket, I thought that due to it being rebored with the bigger than standard piston that the gasket needed to be bigger also.
Stan Stevens who did the rebore told me to put two bottom gaskets to prevent it knocking. As at the time I had nowhere to do the rebuild my garage did it and when I took the top end off there was no second bottom gasket.
To be honest I'm a bit confused
Thanks Adam |
| Back to top |
| alains |
 alains World Chat Champion
| Back to top |
| robboadd |
 Posted: 22:47 - 05 Jan 2006 Post subject: |
I'm still unsure as to it being lack of oil as I checked the plug and if anything it was too oily. I think the best thing is to have another look tomorrow at the oil pump. I don't want to rebuild the top end then have it seize again.  |
| Back to top |
| Kickstart |
 Kickstart The Oracle
| Back to top |
| stinkwheel |
 Posted: 01:15 - 06 Jan 2006 Post subject: |
If you were told to put two base gaskets in a tuned engine and there was only one, the squish is probably way too small which could cause all manner of problems assosciated with overly high compression. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| bidman |
 bidman Crazy Courier
 Posted: 09:21 - 06 Jan 2006 Post subject: |
It also looks like the facing edge on that photo has been catching on something, going by the small chips on the edge of the piston, it may have been catching the lip of the smaller head gasket?
Dan  ____________________ Don't ride it, RAG IT!! |
| Back to top |
| robboadd |
| Back to top |
| Robby |
 Robby Dirty Old Man
| Back to top |
| Kickstart |
 Posted: 17:36 - 06 Jan 2006 Post subject: |
| robboadd wrote: | Yes it does use the TZR engine but the later one I think which is nicosil plated. Hmm so its not looking too good, how difficult is this to sort out? |
Depends what has happened. If someone has just bored it out without doing anything else then the barrel is trashed (but I doubt any engineer with the skills to rebore a barrel would be dodgy enough to just do this). Normally a plated barrel needs replating after cleaning up (any scores are welded up, old plating removed and the barrel replated), which costs ~£100. An alternative is that they bore the barrel out quite substantially and fit a cast iron liner instead. Cost is about the same, but the barrel can be rebored in future to use oversize pistons (oversize pistons generally are only slightly larger, for example the standard size might be a 56mm bore with the 1st oversize being 56.25mm).
In either case it should have been using a standard size piston (unless you have had it bored out to a larger capacity at the same time) so no need for playing with an extra base gasket.
The grey mark on the top of the piston looks to me like a crater (can you confirm?), which suggests detonation. As such this would generate a hell of a lot of heat and could well have caused the seizure (but if it hadn't have seized you would have had a hole through the piston very shortly afterwards).
To repair it you will need a new piston and rings and the barrel repairing / replacing.
If it is detonation then you also need to sort out why this has happened. If it has has some work done at the same time (eg, bored out to a noticeably larger capacity) the you will probably need to adjust the compression to compensate (either the bodge it and scarper route with an extra base gasket or 2, or do the job properly and machine the combustion chamber).
By the way, Stan Stephens probably meant knocking as in detonation rather than knocking as the piston physically strikes the gasket. If the compression is too high then the fuel / air mix can explode rather than burn progressively. Effect on the piston of this is the difference between smacking it hard with a hammer and pushing it down gently by hand.
| Back to top |
| stinkwheel |
 Posted: 21:38 - 06 Jan 2006 Post subject: |
The two base gasket thing coming from a 2-stroke tuning company would suggest to me that the barrel has been altered to adjust the port timing and decrease the squish as a means to gain more power.
Either that or the barrel sealing surface was damaged and had to be skimmed. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| DucatiEVO |
 DucatiEVO Could Be A Chat Bot
| Back to top |
| robboadd |
 Posted: 21:59 - 06 Jan 2006 Post subject: |
Well the only thing as far as I know stan stevens did was rebore the barrell, which meant an increase in capacity but only a tiny amount. When it seized the time before I thought it was just due to me not changing the top end quick enough, the piston was only scored on the outside. This was due to me just buying the bike and as the previous owner told me it had a new top end it wouldn't need one for a while.
The bike was defiently running too rich at some stage as my local garage adjusted the oil pump due to it fowling plugs after a while but this was before the first seizure.
It is really pissing me off I've had it since january and had it on the road for about 2 months. I really don't want to sell it to somebody and have it break down on them, I want to make sure they will get some use out of it. I need to sell it to buy a bigger bike and progress
Edit: When I get a new top end as it will be standard size will I need to worry, will it still suffer from 'detonation'? Do the slight differences in bore and how high the barrell is really make that much difference? |
| Back to top |
| Kickstart |
 Posted: 22:37 - 06 Jan 2006 Post subject: |
A normal rebore would only increase the capacity by a tiny amount (normal .25mm oversize piston would increase the capacity by about 1.1cc, a tiny amount. Unlikely to affect the compression.
However the TZR barrel cannot be rebored, so god knows what has been done to it. Possibly bored out to a fair bit larger capacity and then replated. You need to find out exactly what was done to it.
For a start, measure the diameter of the bore. Also check the top of the piston and see if you can read a size stamped on the piston crown.
| Back to top |
| Cog Head |
 Cog Head Could Be A Chat Bot
 Posted: 00:23 - 07 Jan 2006 Post subject: |
Looks to me that your out of Stella mate  ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore
McGee: Hence I smell like a gimp |
| Back to top |
| smokie |
 smokie Borekit Bruiser
| Back to top |
| robboadd |
| Back to top |
| Kickstart |
 Posted: 22:19 - 10 Jan 2006 Post subject: |
Hell of a lot of pitting around the edge of the head. Looks like either something bouncing around there (eg, bit of circlip) or more likely detonation.
The 2 tends to suggest a 2mm oversize piston, or maybe 2nd oversize (which I would guess would be 0.5mm oversize) so either 58.5mm (or 57mm), but you have measured it at 60mm (and that would suggest 140cc or so).
| Back to top |
| smokie |
| Back to top |
The last post was made 20 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
