How do I change a front brake disc?
byke95
PostPosted: 14:17 - 09 Jan 2006    Post subject: How do I change a front brake disc? Reply with quote
After warping my front brake disc and being in the process of sourcing a new one I need help in getting the existing disc and front wheel off:
It's a KTM Supermoto and I can't get a Haynes manual for it so I've no idea how to do the job...
Any help/tips are much appreciated Thumbs Up
Guest
PostPosted: 17:06 - 09 Jan 2006    Post subject: Reply with quote
At a guess .........
Hold brake on and 'crack' brake disc mounting bolts
Unbolt brake caliper from fork leg and tie up out of the way.
Remove front wheel spindle nut. Slacken pinch bolts if fitted and remove spindle. Remove wheel. Lay wheel flat and remove disc mounting bolts.
Re-assemble in reverse order
Pump brake lever after refitting caliper to bring the pads out.
The last post was made 20 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 2.53 - MySQL Queries: 14 - Page Size: 31.21 Kb
