Method |
Method World Chat Champion
Posted: 13:56 - 19 Jan 2006 Post subject: Woot! Ciggy Lighter Fitted! |
Right
Following on from my thread yesterday that i deleted, i went down to halfrauds and invested in a £5 3 into 1 ciggy lighter for a car.
Brought it home and snipped off the end (The plug).
Split the two wires, as they come glued together.
Connected the earth wire to the battery negative terminal (Using those circular terminal connectors)
Then wired up the live to my ignition wire.
This now means that the cig lighter is only on when the ignition is on, and that if anything goes wrong i can simply hit the ignition off to kill it.
I also fitted an inline fuse of 30amps (might knock it down to a 20 amp though).
Voila, mounted it under my seat, and im good to go
1 Port is allready being used, i got me a small ciggarette lighter powered green accent light, that is now lighting up my clock on the dash for night time use
Now i can run say, Phone charger on it, or i can plug in a portable pump for airbeds when i go camping, or maybe, just maybe, even a ciggarette lighter?
Pics:
Crap picture, but you get the idea... this is the LED glowing over my clock
https://www.bikechatforums.com/files/dvc00381.jpg
Up CLose
https://www.bikechatforums.com/files/dvc00377.jpg
Fitted under the seat, ignition on, so the LED Glow of the ports themselves is visible slightly
https://www.bikechatforums.com/files/dvc00378.jpg ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado
My Bikepics.com - No Brakes, No Gears... No Fear. |
phill.c |
phill.c Traffic Copper
Posted: 14:05 - 19 Jan 2006 Post subject: |
not a bad idea, good if you go on trips all the time. your bike need a fookin good clean tho ____________________ CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed |
Suzuki |
Suzuki Roger
Posted: 14:07 - 19 Jan 2006 Post subject: |
That's a very cool idea. Would be handy to have for charging phones/cameras/etc when camping.
Nice one! ____________________ <Simple> no I'm shaven Jon
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map |
Method |
Ive just got back from college, the shite on the road just coats the plastics in a thick layer in seconds.
But yes, Jetwash is next ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Bod |
Bod Traffic Copper
mr.z |
mr.z World Chat Champion
Posted: 14:18 - 19 Jan 2006 Post subject: |
30 amps is defenately too high, anything over 15 is asking for truoble and fryed wires.. (check your fusebox, if the highest fuse is 10 then thats what you should be useing!, presonally i'd be useing 10amp)
Mobiles and small electronics will be totaly fine air bed pump would be ok too, just be carefull not to overload it (hairdryers, hoovers e.t.c....)
Just be carefull what your pluging in ideally you should be runing this lot off a relay, ignition wire is the switch, power is off the battery, dead easy to fit, get them from a car breakers..
Personally i got one of these, not often i've needed one, its powered an inverter which ran a laptop for a fair bit of time with no probs..
https://www.vehicle-wiring-products.co.uk/VWPweb2000/switch-3/Images/GroupImage20.GIF ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
TOM M |
TOM M World Chat Champion
Posted: 15:06 - 19 Jan 2006 Post subject: |
A really good idea that ____________________ Now owner of a 1200 Bandit |
Posted: 16:52 - 19 Jan 2006 Post subject: |
I have to agree with mr.z. You should really use a relay with that, use the ignition wiring as a 'switching' current. I usually take a switching current off the feed to one of the brake light switches.
With a relay, the load carrying wiring is dedicated to that socket only and not connected to any of the other systems on the bike.
Some of the devices you could put in a cigarette lighter socket are very high draw and would pop your main fuse the way you have it leaving you unable to ride the bike. A good example of one of these high draw devices is a cigarette lighter. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
R4nger |
R4nger World Chat Champion
syl |
syl World Chat Champion
mr.z |
Method |
Posted: 17:56 - 19 Jan 2006 Post subject: |
Yeah i was thiking about a relay, but then it occured to me that i dont actually know how i woud connect one up / how it would work etc... care to explain?
On a side note, just thinking of switching it around, so the live is straght from the battery - then the fuse, then the cig lighter ports, but then where woud i put the earth for a switch? I couldnt connect the earth to the ignition wire because it needs an earth, not a live ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
mchaggis |
mchaggis World Chat Champion
doggone |
doggone World Chat Champion
Knowlsey |
Knowlsey Scooby Slapper
Posted: 18:49 - 19 Jan 2006 Post subject: |
Method |
Posted: 18:52 - 19 Jan 2006 Post subject: |
Lee_367 |
Lee_367 Brolly Dolly
binge |
binge Emo Kiddy
Posted: 02:25 - 19 Feb 2006 Post subject: |
I would Most defonatly use a Relay in that setup because if you do burn the ignition wire out from overload, Then you arent going to beable to start the bike either!
Its easy as to fit a relay to what you have like.
The current live you are using now, Disconnect it from the Ciggy ligher thing, and wire it onto the Switching side of the relay (the Terminal with the LOWER number on it)
Then from the opposite terminal to the (the other low number), Simply earth it.
The for the power, Run a fresh live from battery to the Relay (Terminal with the Higher number on it), Then from the opposite terminal to that, Run it to the Ciggy ligher.
Hey presto, You have already wired the rest up anyway.
This way, it will still come on with the ignition, but its running a Much higher load taking loom, so you wont run the risk of burning somthing out.
<|Ben|> ____________________ - Honda XL125S - CBR400 NC29 - VFR400 NC30 - CBR400 NC29 - TL1000R - TeeZeR Pit! - Bandit 12 - YZF450 - LuckyMX125 Pit! - Demon X XLR 140 Pit!
- Honda Chaly 140cc - Thumpstar 190cc 4v MiniSM - Aprilia RS125 Pit-Bike - |
8Ball |
8Ball Derestricted Danger
Method |
8Ball |
riichy |
riichy World Chat Champion
Posted: 20:20 - 28 Feb 2006 Post subject: |
good ider if you smoke
wonder if they will start putting them as standard on some bikes ____________________ .......... PLOD ............ zx636 2004 |
Teaman |
Teaman World Chat Champion
The last post was made 18 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
