Smokin
Vissie
PostPosted: 19:09 - 09 Feb 2002    Post subject: Smokin Reply with quote
My bike is smoking up the whole place where i start it is this normal ??? Embarassed
Annabella
Like a person, only smaller
PostPosted: 10:40 - 10 Feb 2002    Post subject: Smoke Reply with quote
Have you tried flushing throught the oil? If you've got really old or cheap oil it can have this effect. When I got my bike it had been stoood for about 5 years not going anywhere and was full of gunk. When I started it I gassed everyone around. I flushed it through with some cheap oil first, than put some TTS in (cos it's fully synthetic it will clear out all the gunge).
My bike starts pretty lean now, and it smells lovely too!
Peje
PostPosted: 11:43 - 10 Feb 2002    Post subject: Ne1 got a spliff?-gary Reply with quote
Until she's properly warmed up my NSR smokes like Mito Mad Cunt at the wkend!!!! :o
It kicks out loadsa smoke 4 a while, then runs sweet!!
DrSeuss
PostPosted: 15:44 - 10 Feb 2002    Post subject: Reply with quote
Its just your oil hasn't got properly up to temperature so its not sticking to the cylinder walls. Its fairly normal. MMmmm the smell of two stroke in the morning.
TJ NSR
PostPosted: 16:11 - 10 Feb 2002    Post subject: oil Reply with quote
for the 1st few secs this happens then it clears up once the engine has warmed up
Guest
PostPosted: 11:26 - 11 Feb 2002    Post subject: 2 sroke oil Reply with quote
Razz As Robert Duvall said: "There's nothing like the smell of 2 stroke in the morning...Its the smell of victory!
PostPosted: 13:21 - 11 Feb 2002    Post subject: 2 sroke oil Reply with quote
I was in abike shop the other day and there was a couple of scooter-riders buying strawbery scented two stroke Confused
retrofly
PostPosted: 13:58 - 11 Feb 2002    Post subject: Reply with quote
my two stroke oil smells of mint 4 sum reason Confused
NSRboi
PostPosted: 15:31 - 21 Feb 2002    Post subject: Fully Synthetic Oil Reply with quote
My NSR is just 6 months old. With the cold weather we've been havin my exhaust has been smoking a lot after choke starting; as previous post said, because the oil ain't heated up enough. Also found when temp has been below zero overnight, after choke starting in the morning I get loadsa smoke, the engine has cut out when idling because she was too cold (restarts right away tho) after a mile or two running shes ok.
Usuing Honda Two Stroke Oil at the minute. Question: do have have to frush the stuff out to use Castrol TTS?, or will it be ok to top up?
Rolling Eyes
RFT
PostPosted: 17:09 - 21 Feb 2002    Post subject: Reply with quote
I hope so...
I've been topping up my standard oil with TTS...
my bike's been dispalying the same symptoms as yours- must be the weather...
2 strokes is all it takes...
Russell
PostPosted: 17:57 - 21 Feb 2002    Post subject: Smoking too Reply with quote
My new NSR (2001) sometimes 'smokes' too. Using TTS oil, some days its ok, some days not.
Russell
The last post was made 23 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 64.39 Kb
