Chain & sprocket
Cog Head
PostPosted: 01:12 - 26 Jan 2006    Post subject: Chain & sprocket Reply with quote
when i brought my bike, it had a new chan and sprockets fitted, and i was they first person to use it as we picked it up from the garage where it was done.
but since i have fitted my race system, my chain keeps stretching, last weekend me dad tightened my chain for me, and iv just notice that its gone really slack again Shocked
Ad my question is, would it be worth upgrading the chain and sprockets to a 125 chain and sprockets, im guessing that they are stronger... Mr. Green
What do ya reckon?
**EDIT**the bike is a rieju rs2 50cc if you dont already know**EDIT*
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
colin1
Captain Safety
PostPosted: 05:27 - 26 Jan 2006    Post subject: Reply with quote
i reckon you arent tightening up the back wheel nut tight enough.
PostPosted: 13:05 - 26 Jan 2006    Post subject: Reply with quote
Depends why it is "stretching". Keeping it lubed is very important.
Some 50s do have pathetically small chains, but you might struggle to find a set of sprockets to match a larger chain. And as an example of how strong chains are, most current 125s use a 520 chain, the same size as they used on the 500cc GP bikes putting out 150~200hp.
If keeping it lubed doesn't work (and check that it is not just the rear wheel moving on the adjusters) then consider a better quality chain / heavy duty chain.
ancientd
PostPosted: 16:24 - 26 Jan 2006    Post subject: Reply with quote
You may also have problems getting the right fitting for the front and rear sprocket. Being a 50 I very much doubt that the chain is actually stretching that much but as has been suggested the rear wheel may be moving, depending on how it's actually locked into the swinging arm. If you're not happy with it get a new set, if you go to a good spares supplier they may be able to upgrade your set but it's hardly worth it, a 50 cc bike don't put out that much power.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
The last post was made 20 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.08 - MySQL Queries: 14 - Page Size: 40.81 Kb
