| LT |
 LT L Plate Warrior
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 11:54 - 27 Jan 2006 Post subject: |
No no no.
Generally the take off's to ballance carbs are on the inlet to the head, where the carb rubbers mount onto the head. Will usually be either covered with a small bolt, or a small piece of hose with the end blocked. Well, on the ones I've seen anyway. |
| BFG |
 BFG Brolly Dolly
| Kickstart |
 Kickstart The Oracle
 Posted: 12:45 - 27 Jan 2006 Post subject: |
Those are not the vacuum take off point for balancing the carbs. Those caps are over the end of the bar that operates the throttles. Basically the bar turns and pulls up the throttle slides. I do not know, but possible that there is something under that cap to allow you to adjust the connection between the bar and the slides to synchronise them (ie, balance them), but this is unlikely. I would expect the adjuster to either be between the carbs on the bar or under the caps on the very top of the carbs.
I agree with BFG on his choke comments. Fairly certain they are not the fuel feed, but not a clue what they are for.
| BFG |
 BFG Brolly Dolly
| Kickstart |
 Posted: 12:55 - 27 Jan 2006 Post subject: |
| BFG |
 BFG Brolly Dolly
 Posted: 13:07 - 27 Jan 2006 Post subject: |
That was helpful Keith
The idle mixture screw I believe is left side pic, right hand side, half-way up. No 44 "air screw" in diagram. So, no cap removal required.
That black outlet would be in the right position to be an overflow outlet. If so, just for running tubes to the underside the bike. |
| Barry_M2 |
The last post was made 20 years, 250 days ago. Instead of replying here, would creating a new thread be more useful? |
