davetbee |
 davetbee L Plate Warrior
 Posted: 17:38 - 29 Jan 2006 Post subject: KAWASAKI ZZR 1100 ENGINE PROBLEM |
Hi, i have an autograss car wich has a kawasaki zzr 1100 engine in it. Down low in the revs the engine bakfires, splutters nd dus evertin not rite and is totally un usable , as soon as the revs eventually build up to about 6000 it seems fine and drives really well, the engine has a different set of carbs and it has no alternator so the battery goes flat, and maybe it wont provide a good enough spark???????? there is also a loud knock wich i kno comes from a dodgy cam and follower, so cud it be that, but wont that get worse up the revs???????? does ny1 know exactly whats wrong i would really appreciate any help  ____________________ D alexander |
woodyfjr |
 woodyfjr Scooby Slapper
Kickstart |
 Kickstart The Oracle
 Posted: 17:52 - 29 Jan 2006 Post subject: |
If the battery has a decent amount of charge then the lack of a charging system is probably not the problem. Also suspect that the CDI would might only have issues if the power supply is too lower but with no charging it would not get better with revs. A problem with the coils would likely get worse with revs (higher revs means less time for them to "charge up").
What carbs are you running? Have they been set up for the engine in its current state of tune?
davetbee |
sickpup |
 sickpup Old Timer
davetbee |
sickpup |
 sickpup Old Timer
Kickstart |
davetbee |
Kickstart |
davetbee |
Kickstart |
 Posted: 23:15 - 29 Jan 2006 Post subject: |
If it is backfiring in the exhaust then it suggests the exhaust valves are either not doing their job (ie, cam timing out, valves not sealing) or far more likely it is dumping large amounts of petrol down the exhaust.
Vacuum gauges are mainly for balancing the carbs but if they are a nightmare to balance then it suggests an issue with the cylinders.
ZRX61 |
 ZRX61 Victor Meldrew
bish777 |
 bish777 World Chat Champion
The last post was made 19 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
