Any Ideas?
RS125_Tecky
PostPosted: 02:48 - 12 Feb 2006    Post subject: Any Ideas? Reply with quote
From about 11k revs onwards the revs shoot up and the bike revs but it doesnt pull any more power, does something need adjusting?
Bike is a 01 zx6r j2.
2004 ZX6R B1H
White Noise
Mr Dudwee
PostPosted: 02:51 - 12 Feb 2006    Post subject: Reply with quote
maybe suffering from clutch slip, your cluch may need adjusting. have you changed your oil recently?
WN
RS125_Tecky
PostPosted: 02:54 - 12 Feb 2006    Post subject: Reply with quote
WN
No not changed the oil recently.
How and where do i adjust the clutch from?
2004 ZX6R B1H
NC30UK
Sounds like youve put car oil or something in it Laughing
Check your clutch cableslack and adjustment, if still no good give it an oil and filter change (wouldnt hurt it anyway probably!) if still no joy then it's new clutch plates (bout £50+ fitting)
RS125_Tecky
PostPosted: 02:57 - 12 Feb 2006    Post subject: Reply with quote
So should I adjust the cable outwards from the clutch lever?
2004 ZX6R B1H
White Noise
Mr Dudwee
PostPosted: 02:59 - 12 Feb 2006    Post subject: Reply with quote
on my 7R the clutch is hydrolic, is it the same on the 6R?
if its cable there should be an adjuster just above the clutch case cover, if its hydrolic is should be automatic
WN
NC30UK
when the cable is pulled the clutch slips.
so you want to let some tension off the cable as it might be pulling slightly all the time.
so screw in the adjuster on the clutch lever.
start the bike, put it in 1st gear and let the clutch out slowly untill it bike begins to creap forwards, thats the biting point. adjust the cable tension untill the bite point is about half way along the levers movement.
RS125_Tecky
PostPosted: 03:02 - 12 Feb 2006    Post subject: Reply with quote
Will try that tomorrow.
So i want to be adjusting it inwards and not outwards?
2004 ZX6R B1H
RS125_Tecky
PostPosted: 03:03 - 12 Feb 2006    Post subject: Reply with quote
WN
Its cable, Thumbs Up
So which way do I adjust it?
2004 ZX6R B1H
TL666
PostPosted: 03:17 - 12 Feb 2006    Post subject: Reply with quote
There's also a little pushrod thingy that can sometimes need adjusting. Maybe someone can explain it to better than I can. Embarassed
ZRX61
Victor Meldrew
PostPosted: 04:22 - 12 Feb 2006    Post subject: Reply with quote
slacken the cable, ring spanner on the lock nut (usually 12/13/14mm), turn the slotted adjuster thingiemagummer inside the locknut until ya feel resistance, back it off 1/4 turn & tighten the lock nut. Thumbs Up
Then adjust the cable......
RS125_Tecky
PostPosted: 12:24 - 12 Feb 2006    Post subject: Reply with quote
Cheers for that but im lost.
Wheres the locknut?
2004 ZX6R B1H
White Noise
Mr Dudwee
PostPosted: 12:28 - 12 Feb 2006    Post subject: Reply with quote
RS125_Tecky wrote:
Wheres the locknut?
take look at the bottom of this page, HTH
https://www.dansmc.com/clutches.htm
WN
RS125_Tecky
PostPosted: 12:54 - 12 Feb 2006    Post subject: Reply with quote
White Noise wrote:
RS125_Tecky wrote:
Wheres the locknut?
WN
Cheers for that.
Sounds hard to do might have to get it into a garage Sad
2004 ZX6R B1H
White Noise
Mr Dudwee
PostPosted: 13:02 - 12 Feb 2006    Post subject: Reply with quote
its really easy!
download this and i'm sure you can figure it out, just look uo clutch adjustment!
https://www.diff.ru:8000/Kawasaki_ZX-6R_'00-02_Service_Manual.zip
WN
Cillit-BANG
PostPosted: 15:08 - 12 Feb 2006    Post subject: Reply with quote
So I take it you bought it then? Thumbs Up
The last post was made 20 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.64 - MySQL Queries: 17 - Page Size: 97.55 Kb
