Help , weird noise from Citeron Saxo
dransy
PostPosted: 23:57 - 14 Feb 2006    Post subject: Help , weird noise from Citeron Saxo Reply with quote
Hi all my best mate was in her saxo on night and there was a road sign in the road and a wagon coming the other way, she had no option but to drive straight over it.
Anyway to my point , when going down a hil the front left wheel starts whining like something is rubbing , but it only happens when going down a hill?
I dont know much about cars but i thought it might be the wheel bearing , and she also said that it only happens when someone else is in the car lol?
Any ideas? i know its a long shot
Cheers marc
R4nger
PostPosted: 23:59 - 14 Feb 2006    Post subject: Reply with quote
Have you actually looked under the car?
Irezumi aka Reuben
Carrot Top
PostPosted: 00:02 - 15 Feb 2006    Post subject: Reply with quote
Sound's like something's broken to me.
Pictorgraphicalfantastical
Klause
PostPosted: 00:08 - 15 Feb 2006    Post subject: Reply with quote
Drive out of her street, keep going straight ahead, I'm sure you will find a cliff Thumbs Up .
Erm, Whining hey, doesn't sound like it would be metal on metal then if it was whinning noise. I dunno, hate cars.
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
dransy
PostPosted: 00:10 - 15 Feb 2006    Post subject: Reply with quote
If i looked under the car i wouldnt know what to look at , obviously around the wheel area , but i dont see why it only does it going down a hill
Its like a deep whining aswell i should mention
cheers marc
binge
Emo Kiddy
PostPosted: 01:17 - 15 Feb 2006    Post subject: Reply with quote
is the car pulling at all?
Sometimes if the tracking has been knocked out enough it can cause all sorts of strange things to happen.
Im sure on the Shitron Saxo, The brakes and Suspension Hydraulics all interlink.
could be anything, But its probably not that serious.
Take a look under the car (on the drivers side and passeneger side) and just compair both sides.
Your best bet is to probably drop it in at the local Kwikfit, Checks are free anyway. I get them all day long.
Get the tracking checked too.
Only thing is, if its damage to the brakes, i dont think Kwikfit can touch them as the Shocks and brakes are all one system, Its strange and very complexed on the citrons.
SteWhit
PostPosted: 04:44 - 15 Feb 2006    Post subject: Reply with quote
Are you sure it only started after she ran over the sign? We have a Saxo too which was making the sound you described. Looked all over to see what was making it, had all the wheels off and checked all the bearings and could see anything wrong. Turned out that the CV boot had come off and joint had dried out and was grinding. I just refitted the boot and re-greased it and all was ok. Although when this happened it did mean that the CV joint was nackered and has now started to knock like hell, another job i need to get round to doing.
Are You Serious??
Nb
PostPosted: 17:58 - 15 Feb 2006    Post subject: Reply with quote
Not on the saxo they arent.
Like the above post, sounds like cv joint/boot issue. I had a funny noise on mine once and it turned out to be the cv boot clip had come undone, which started rubbing causing a nasty noise. Take it to a garage you trust and get them to have a look. Thumbs Up
dransy
PostPosted: 23:46 - 15 Feb 2006    Post subject: Reply with quote
CV joint? whats this? i know nothing at all about cars just basic maintanance etc .
Marc
MikeyC
PostPosted: 23:49 - 15 Feb 2006    Post subject: Reply with quote
There was a whining noise?
You sure my missus weren't sitting in the back seat? Laughing
WR450_geezer
Nobody likes me
PostPosted: 00:00 - 16 Feb 2006    Post subject: Reply with quote
It was a Saxo, all noises and breakages come with the car from new.
WR
Siggi, ''Fack, having Daz around is like living next door to PC-World, with a hole in the wall.''
SteWhit
PostPosted: 00:12 - 16 Feb 2006    Post subject: Reply with quote
CV joint is the thing that attaches the wheel to the drive shaft. They need to be lubed at all times. The have a rubber sleeve over them called the boot. This is full of grease and clipped at each end. If one of the clips comes off you end up loosing all the grease which causes the joint to fail and make grinding sounds.
Some cars you are able to change the joint on it's own, but i think the Saxo has all in one drive shafts/CV joint so you make need a new drive shaft. Our car does... desperatly! There not too expensive, priced up a second hand one the other day it was only £30.
Are You Serious??
gammamanuk
PostPosted: 10:08 - 16 Feb 2006    Post subject: Reply with quote
Another great french build quality thread.
Sounds like its mashed the wheel bearing.
List of possibilities
CV Joint
Wheel Bearing
Suspension Coil Spring possibly snapped and rubbing on inside tyre wall, ive seen that happen before Smile
Johnny GSX-R
PostPosted: 10:14 - 16 Feb 2006    Post subject: Reply with quote
What a load of garbage i'm reading.
Why are people who CLEARLY know NOTHING about motor vehicles giving advice on them.
'Smashed wheel bearing' FFS Rolling Eyes
'Hydralastic suspension' on a SAXO Thumbs Down
1st thing to do is get the car into a garage so they can get it up on the ramp and have a damn good look around it, if the sign has caught a brake line or cut into a tyre etc you really need it sorting. As for the noise, without being able to hear it then it like pissing in the wind..
numark1
Scared of girls
PostPosted: 10:40 - 16 Feb 2006    Post subject: Reply with quote
WR
My car doesn't break down much or make weird noises. Confused
lilredmachine
PostPosted: 13:03 - 16 Feb 2006    Post subject: Reply with quote
If you had an XM Rolling Eyes
WR450_geezer
Nobody likes me
PostPosted: 13:25 - 16 Feb 2006    Post subject: Reply with quote
markcatate wrote:
WR
markcatate wrote:
Posted: 08:35 - 01 Feb 2006
Got to work and tried to switch the ignition off and the keys jammed in the barrell, wont turn or anything. Also the steering wheel is really heavy like theres no power steering.
numark1
Scared of girls
PostPosted: 15:00 - 16 Feb 2006    Post subject: Reply with quote
I said much. Wink
Since september i've broken the ignition barrel, fuel pump and central locking. Embarassed
binge
Emo Kiddy
PostPosted: 01:45 - 19 Feb 2006    Post subject: Reply with quote
You think thats bad!?!
You should try owning a Mini! Shocked
I can honnestly say I can NOT go 24 hours without a problem. Could be anything, Somthing silly like a dodgey connection.
Its got a faulty coil on it too, So After every 10 miles or so, It decides to die, The Backfire, then the engine comes on for a second. Then it dies completely (even at like 70mph on motorways). And IM forced to Coast into the H/s where it requires 10 minutes "rest". Razz
306_abb
PostPosted: 14:59 - 19 Feb 2006    Post subject: Reply with quote
c.v boot has dryed up happens to most french cars fill it with grease
spitfire
PostPosted: 15:18 - 19 Feb 2006    Post subject: Reply with quote
I think the Saxo might have the same suspention setup as my good lady's AX.
If so it will have torsion bar rear suspention, and not springs like on real cars. If the bushes fail then the rear wheel(s) tend to angle inwards and rub against the inside of the wheel arch...could be that, you will need to get it up on the ramp to have a look. If it is you are looking at £400 + to fit a second hand sub frame.
The last post was made 19 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 3.29 - MySQL Queries: 13 - Page Size: 111.75 Kb
