monkeyking118 |
monkeyking118 Borekit Bruiser
Posted: 19:52 - 15 Feb 2006 Post subject: Idling probs and bike that keeps going with no key! |
Started up my bike this afternoon (can't ride yet so i'm just testing stuff out) and the engine will not idle without the throttle open.
idles fine when in choke or half choke at 1.4k, but refuses point blank to idle with no choke. it starts fine as long as the revs hit above 2k, any less and it just dies, whats gonig on, and isn't this a problem when i do actually ride my bike?
now the second part of the prob...
when in choke or half choke, the bike continues to idle AFTER the ignition has been turned off... i can even take the key clean out and it sits there happily ticking over! (obviously i do not know if this happens without the choke, because it won't idle anyway!)
I'm very confused about this! ____________________ Baimo RSR125(sold), Suzuki En-125 '06 (sold), Honda VFR400 NC-30 '92(sadly stolen), Kawasaki ZX6R Ninja '96 (sadly stolen), Kawasaki GPZ500s '93 (sold), KTM rc390 '16 (f***ing stolen) |
Posted: 20:11 - 15 Feb 2006 Post subject: |
Check your sparkplug. In some cases there can be a buildup of carbon on it which causes the engine to 'run-on' after switching off. More likely there is a fault on the ignition switch or the connections to it.
If you aren't riding it, I have my doubts if it will be getting warmed up enough to idle properly. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
monkeyking118 |
Posted: 20:56 - 15 Feb 2006 Post subject: |
Just so you know. The usual case is that the ignition switch MAKES a connection between a wire coming from the ignition coil and earth when you switch it to 'OFF'. Earths the spark, kills the engine. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
www.125power.com |
www.125power.com Crazy Courier
Posted: 01:22 - 16 Feb 2006 Post subject: |
Cleaning the thread of the plug and the thread on the cylinder block may help it earth better..... ____________________ My eBay Items |
monkeyking118 |
sickpup |
sickpup Old Timer
monkeyking118 |
Posted: 14:03 - 18 Feb 2006 Post subject: |
Almost certainly. Sounds like the wire running from the coil up to the ignition and stop switches is detached or broken. That or the earth connection from these switches is broken or rusty (assuming they share an earth connection). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
meooo |
meooo Nova Slayer
meooo |
meooo Nova Slayer
sickpup |
sickpup Old Timer
meooo |
meooo Nova Slayer
Gazdaman |
Gazdaman I did a trackday!!!
sickpup |
sickpup Old Timer
meooo |
meooo Nova Slayer
meooo |
meooo Nova Slayer
Posted: 14:14 - 20 Feb 2006 Post subject: |
I'll put it another way. You can start my CDI ignition Honda H100 with no battery in the bike. When I got it it had the ignition switch wired up wrong and had had a seperate button fitted to to earth the spark and kill the engine.
Many (most?) smaller capacity bikes have a totally seperate coil on the stator for the ignition which generates power all the time the engine is turning. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
meooo |
meooo Nova Slayer
Gazdaman |
tribal_tiger |
tribal_tiger World Chat Champion
Posted: 13:42 - 28 Feb 2006 Post subject: |
Some people know nothing!!!
This is a dodgy earth connection. I told this to the guy i sold it to, and I thought I'd mentioned it to Monkey as well!
As for the idle problem. Once it warmed up properly it's fine. I know it's OK now you've adjusted it, but I think you'll find that when you are riding it, it will now idle a bit high. I found if the bike was sitting and you were waiting for it to warm up it took ages. I'd wait a minute or two then ride it gently. After a mile or even less it would be warmed up, and the revs would be fine!
Honestly, I'm away for the board for a while and look at you!!! ____________________ How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it. |
monkeyking118 |
The last post was made 18 years, 62 days ago. Instead of replying here, would creating a new thread be more useful? |
