lilredmachine |
lilredmachine World Chat Champion
Kickstart |
Kickstart The Oracle
lilredmachine |
Kickstart |
Posted: 14:39 - 16 Feb 2006 Post subject: |
You missed the point entirely. That Gixxer engine has almost 10 times the capacity. The 125 kart I mentioned has the same capacity as the CBR engined sidecar you mentioned. Should be close to the same rolling resistance and aerodynamics. Yet the 2 stroke has around a 30mph speed advantage (not surprising as it is one hell of a lot more powerful than the 4 stroke has any hope of being).
That a larger engined 4 stroke vehicle is more powerful is of no relevance when we are talking about the advantages of 2 strokes over 4 strokes. I could quite happily have found figures for 160mph+ 250cc karts.
lilredmachine |
Kickstart |
Posted: 15:18 - 16 Feb 2006 Post subject: |
Right, so now we get to the truth that the 125 side car class is limited to 4 strokes. If so that is why they are limited to the slower 4 strokes rather than the faster 2 stroke. So if "They want more, if it is possible, it is assumable that they have done it".
What is the point of using a class restricted to 4 strokes to try and show that they are better than 2 strokes?
The kart was merely mentioned as being something with a similar drag to the 4 stroke you mentioned but with massively more power due to its 2 stroke engine. Rather destroys your comment that "There is no physical reason for 4 stroke 125s to be less powerful than 2 strokes", especially when there has been one hell of a lot more development in 4 stroke engines than in 2 strokes.
lilredmachine |
Kickstart |
Posted: 15:29 - 16 Feb 2006 Post subject: |
No. You started out with the comments that there is no reason why 4 strokes should be less powerful (there are reasons). You have then gone one to try and show how powerful 4 strokes are with an example of a sidecar 4 stroke, which is pretty slow compared to a rough 2 stroke equivalent.
While development may make 4 strokes more powerful, they have got a hell of a long way to go to catch up with 2 strokes, and that is despite far more development resources having gone on the 4 strokes over the years.
Chances of a 30hp 125 4 stroke in a road bike is nil in any reasonable timeframe.
lilredmachine |
Kickstart |
Posted: 15:43 - 16 Feb 2006 Post subject: |
Fair enough, but you did try to say that they can be as good as 2 strokes for power which is a long way from the truth, when a good Moto GP 4 stroke engine requiring very regular rebuilds manages about the same specific horse power as a 2 stroke road bike.
Only way that 4 strokes come out OK in racing is because the rule books are (now) written to favour 4 strokes. When in the GPs the rules just specified the engine capacity nobody had bothered to race a 4 stroke since the early 80s when Honda tried and failed to compete with the hideously complicated but still slow NR500.
If they could get competitive power from a 4 stroke then they would have raced them.
Nath |
Nath World Chat Champion
fuzz wrote: | The piston travelling down the cyclinder creates the vacuum to draw in fresh mixture in a 4t. In a 2t, the piston forces stored fuel up into the cylinder, which forces out the exhaust gases. If a 2t had valves, both would need to be open at the same time, and there would be little vacuum effect to draw in fresh mixture (assuming he inlet port was larger). |
Except that you wouldn't need much vacuum to suck in fresh fuel, if it s being forced in by fuel injection. Imagine the potential if you supercharge it. The exhaust gasses are helped out by the rising cylinder displacing them. You would only need to have the inlet valve open a little bit longer than the exhaust valve in order get the mixture under high compression.
NC30UK wrote: | Look how much 4 stroke bikes have progressed over the past 30 years. in the 60's a CB750 made 60bhp, now bikes of lower capacity that that make double the power. |
But the CB750 was not cutting edge technology for the time compared to race bikes. Looking in a book I have, the (four stroke)1957 Gilera 500c IL4 race bike put out 70bhp and was capable of 165mph! You own example: The RC165, a 250 putting out 60bhp and capable of 150mph. In 1961, the two stroke MZ125 race bike was producing 25bhp, which is the same amount as the road bikes of today, 40 years on. And Suzuki's 1967 125 two stroke racer made 42bhp.
The technology is not the problem, it's making it affordable so it can be used on roadbikes that it is the stumbling block. Clearly not a problem that worried the racebike designers of the 1960s. It is all about money really. ____________________ Hard livin', hard luck. |
NC30UK |
NC30UK Scooby Slapper
fuzz |
fuzz World Chat Champion
Kickstart |
Jack_Cheese |
Jack_Cheese World Chat Champion
Kickstart |
fuzz |
NSR Mick |
NSR Mick World Chat Champion
Nath |
Posted: 17:56 - 16 Feb 2006 Post subject: |
Jack_Cheese wrote: | which would probably make it as slow as a 4t iff you removed the expansion chamber. |
Not really, as you still have more firing strokes. At the very least, you would be able to achieve the same power as on a four stroke, but without the need for high engine speeds.
fuzz wrote: | However as the piston rises it will be on compression stroke, so it would also be forcing out fresh fuel. The exhaust design does help stop this on 2 strokes but then when the piston decends, it will also be drawing in exhaust gases. The effect of porting on a 2 stroke forces the waste back out again. |
Surely the problem with conventional two strokes is that the back pressure from the expansion chamber is only effective at certain engine speeds, so the rest of the time you are getting worse performance and poor economy.
The problem with the valved two stroke would be clearing the exhaust gasses and then closing the exhaust valve before the incoming mixture starts leaving as well. With modern technology and the amount of development that is done on gas flow, it should be possible to make this work, but perhaps the valve timing would have vary with engine speed, adding further complexity?
I was not really thinking about this as an answer to the disappearance of small two strokes. I was really thinking about the dominance of the four stroke engine in general. The large two strokes of the 1970s lost out on fuel economy. Is the the fact that you would need a sidevalve design the only thing that stopped the development of poppet-valved two strokes, Kickstart? ____________________ Hard livin', hard luck. |
Kickstart |
Posted: 19:14 - 16 Feb 2006 Post subject: |
Dare I bring up the subject of wet-sump 2-stroke twins with a 180 degree crank and transfer ports between the two cylinders which effectively do not need oil in with the fuel? (Didn't Ariel make one back in the 1950's?)
Yamaha currently make a V6 high pressure direct injection 2-stroke with a capacity of 3.3 litres producing 300hp. Unfortunately they are only fitted to outboard motors as yet. Had one on the boat we hired in Florida last year. An 18 foot boat with a fully planing hull and anything over half throttle would have flipped it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
LUXY DJ |
LUXY DJ World Chat Champion
Posted: 19:26 - 16 Feb 2006 Post subject: |
you seen how much these NEW! diesels spit out BLACK sortty smoke......(&this is a improvement ) ____________________ GSXR750
(FAR FAR from standard) www.gixerjunkies.net |
fuzz |
Posted: 19:49 - 16 Feb 2006 Post subject: |
Another point worth dropping into the discussion is that race engine designs are not driven by what is fastest/most powerful. They introduce regulations to encourage development in the direction the manufacturers would like to see their road bikes go.
It was done back in the 70's when people were making ludicrous engines like a 4-valve per cylinder, 250cc inline six. The use of multiple, tiny pistons made for a very fast bike but had no chance of transferring to a saleable machine. So they brought in a minimum single cylinder capacity rule.
They did the same with 2-strokes, mainly by allowing the 4-stroke machines much more leeway on weight than the 2-smokes, effectively giving the 4-strokes an artificial advantage. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 18 years, 72 days ago. Instead of replying here, would creating a new thread be more useful? |
