18_stuart_88 |
18_stuart_88 World Chat Champion
Posted: 12:56 - 22 Feb 2006 Post subject: RS 125 Spark Plugs! |
Hello all,
Im having considerably high amounts of problems with my bike at the moment which is leading me on to selling it.
I have went through 6 ( going on 7 ) spark plugs within riding my bike 500 kilometres to and from work.
I realise the problem before the plug completly give way on me so i stop and take it out and give it a little clean up and shot off again, this solves the problem for about 5 mins and then it starts to happen again.
When im riding it becomes very very rough and cuts out on me when i come to a stop or pull in my clutch in any gear. It seems a bit like the bike is missfiring when riding as when i pull the throttle it isnt as responsive as normal. It feels a little like when your about to run out of petrol with the throttle.
y bike runs on a BR10 EG spark plug. Tried the BR10 EIX but it gave me the same problems. I have also got a 34mm Carb apposed to the standard 28mm.
Does anybody know what can be causing me to go through a spark plug ever 4 days or soo?
Any help would be greatly appreciated.
Stu ____________________ Make: Honda NSR 125 R Year: 2004 Colour: Black And Silver - Died on December 18th 2005, Layed to rest December 30th 2005 :(Make: Aprilia RS 125 Year: 2000 Colour: Black And Red - Derestricted Sold!
Make: Suzuki GSXR 600 SRAD Year: 1998 Colour: Red - White - Blue
Pic of My New Bike!! |
Kickstart |
Kickstart The Oracle
18_stuart_88 |
Posted: 13:12 - 22 Feb 2006 Post subject: |
Hi,
Its realy hard to describe how the bike runs when the spark plug is about to give up the game on me.
The only way i can describe it is, it does not run as smooth as it should and it is very rough and bumpy when i use the throttle, if i try to go above the power band it throughs the about the place backfiring and miss firing and puffing smoke everywhere.
Just the way it feels when your about to run out of petrolium.
Skunkcap Freddie |
Skunkcap Freddie Brolly Dolly
Rob W |
Rob W World Chat Champion
Posted: 13:36 - 22 Feb 2006 Post subject: |
As the others have said, seems like your jetting is way off. When I got knocked off in July /something/ happened to my carbs, and the bike would never run smoothly. Used to bog down between 4-8Krpm, but above and below that it was fine. When the gasket blew and I had a good look at the pistons, number 1 was covered in carbon so it had obviously been running rich even though the jetting was standard and the carbs were balanced and had been cleaned/inspected literally about 10 times and I could see NOTHING wrong with them.
In the end I had to get a new set of carbs and that sorted the problem. Try finding some settings for your carb and try them, if not revert back to the original one, that may solve your problem.
____________________ '16 GSX-S1000F |
Kickstart |
Posted: 13:42 - 22 Feb 2006 Post subject: |
From the description it sounds like the way a bike behaves when you leave the choke on too long.
For a 34mm carb on the RS it should be around a 1650~160 main jet. However that is only really going to be important on full throttle, and on a short commute to work you are probably nowhere near that. As such probably check the needle jet position.
Also check that the choke is not sticking on (possibly from an incorrectly routed cable, pulling it on when the bars are turned one way). The needle valve in the carb could also cause problems, but it this way the problem then parking up without swiching the petrol off would result in a flooded engine.
theshmoo |
theshmoo Bottomless Pit
Skunkcap Freddie |
Kickstart |
tommyboi |
tommyboi Borekit Bruiser
Posted: 19:47 - 22 Feb 2006 Post subject: |
if you do end up selling give me a shout |
18_stuart_88 |
Posted: 23:51 - 22 Feb 2006 Post subject: |
There is no way the guy will give me the 28mm Carb Shmoo!
Kickstart + Skunkcap Freddie should the 34mm carb only be good for high speed riding? Or should it be ok with both High speed riding and town commutting?
I mostly do town commuting to and from work 5 days a week. Could this still be down to the Jets being set up wrong that this problem is still excisting?
I have emailed Matt Cooper i think it is at Dellorto to see if he suggests the problem could be down to my Jets and have asked him to give me a price and match of jets which would be suitable for my carb to make it run smoother and stop all my spark plugs fouling.
Kickstart |
colin1 |
colin1 Captain Safety
Kickstart |
18_stuart_88 |
Posted: 22:42 - 23 Feb 2006 Post subject: |
Hi Keith,
The problem tends to arrise when im riding normal likes commuting to work speeds of 30mph - 40mph.
So do you reckon this could be a Jetting problem. If i was to buy new jets from Dellorto and try that would it do any harm to the bike?
Do you know which jets i may need? The only engine modification i have to the bike is the 34mm carb.
colin1 |
Kickstart |
Posted: 12:35 - 24 Feb 2006 Post subject: |
Would guess that jetting is the main issue. Any idea what jetting you are currently running? What position is the clip on the needle jet?
Running a hotter plug round town will probably solve the problem. Trouble is that doing this at speed will not increase wear to the engine but instead result in the plug getting far hotter with the possiblity of it failing dramatically and expensively (more likely to just have the plug die).
18_stuart_88 |
Posted: 12:24 - 25 Feb 2006 Post subject: |
Hi,
It seems that the Carb has a 158 Main Jet in it.
any ideas?
Kickstart |
NC30UK |
NC30UK Scooby Slapper
Kickstart |
18_stuart_88 |
Posted: 00:47 - 26 Feb 2006 Post subject: |
Hi,
So do you reckon i could try and fit a 148 Main Jet and see what diffrence that does to the bike?
Thats what the previous owner had with the Carb but then decided to change it to the large Main Jet.
Kickstart |
18_stuart_88 |
Posted: 00:58 - 26 Feb 2006 Post subject: |
Nice One! Youve been a Superb help Keith.
I'll let you know how i get on when i try new Jets.
Thanks
Kickstart |
The last post was made 18 years, 66 days ago. Instead of replying here, would creating a new thread be more useful? |
