-Savage- |
-Savage- World Chat Champion
Posted: 18:32 - 25 Feb 2006 Post subject: dot3, dot4, or dot cotton? |
ok, i hove some dot3 hydrolic fluid here, but my front brake reservoir says it needs dot4. whats the difference? and should i risk using dot3? ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
Peugeot Speedfight 100, Kymco Hipster 125, GSXR750K5, Jawa TS 350 |
Kickstart |
Kickstart The Oracle
Posted: 19:24 - 25 Feb 2006 Post subject: |
Probably more info than you want to know, but:-
Quote: |
DOT 3: This brake fluid has a glycol base with additives. It is clear to amber in color. It is hygroscopic (meaning it absorbs moisture) and has a minimum dry boiling point of 401°F (205°C) minimum and a minimum wet boiling point of 284°F (140°C). It will absorb 1 to 2 percent of water per year depending on climate and operating conditions. It is used in most domestic cars and light trucks in normal driving. It does not require cleaning the system and it can be mixed with DOT 4 and DOT 5.1 without damage to the system. The problem with it is that it absorbs moisture out of the air and thereby reduces its boiling point. It can also damage the paint on a vehicle.
DOT 4: This brake fluid also has a glycol in it but the SAE J1704 specification considers it to be a borate ester base fluid. Typically in the high performance fluids, it also contains other additives. It is clear to amber in color. It is hygroscopic (meaning it absorbs moisture) and has a minimum dry boiling point is 446°F (230°C) and minimum wet boiling point of 311°F (155°C). It is used in many European cars; also for vehicles in high-altitude, towing, or highspeed braking situations, or ABS systems. It does not require cleaning the system and it can be mixed with DOT 3 without damage to the system. The problem with it is that it absorbs moisture out of the air and thereby reducing its boiling point, however it absorbs moisture at a rate slower than DOT 3. It can also damage the paint on a vehicle.
DOT 5: This brake fluid has a silicone base. It is purple in color. It is NOT hygroscopic (meaning it cannot and will not moisture) and has a minimum dry boiling point of 500°F (260°C) and a minimum wet boiling point of 356° (180°C) It is not used in many brake applications, seeing primary duty in weekend, antique, and collector cars that sit for long periods and are never driven far. It does not mix with DOT 3, DOT 4, or DOT 5.1. It will not absorb water and will not damage the paint on a vehicle. It is also compatible with the same rubber formulations as the DOT 3, 4 & 5.1 fluids. The problem with it is that it can easily get air bubbles into the system. The air bubbles are nearly impossible to remove and result in poor system performance and poor pedal feel. Although originally developed in the late 1960's by General Electric specifically for racing, it is unsuitable for racing for a variety of reasons. If as little as one drop of water enters the fluid, severe localized corrosion, freezing, or vapor lock may occur. This can happen because water is heavier and not mixable with silicone fluids. It is unsuitable for ABS.
DOT 5.1: This brake fluid is similar to DOT 4 it has a base comprised primarily of Borate Ester. Often in the range of 70 - 80%. To meet specification, it also will contain other additives. It is clear to amber in color. It is hygroscopic (meaning it absorbs moisture) and has a minimum dry boiling point of 500°F (260°C) and a minimum wet boiling point of 356°F (180°C) minimum. It is almost exclusive to Europe, used in high performance cars. It can be mixed with DOT 3 or DOT 4 without damage to the system. It maintains higher boiling point than DOT 3 or DOT 4 fluids due to its even greater borate ester content. It is excellent for severe duty and racing applications. The problem with it is that it costs more than other fluids and there is limited availability in the USA. It also absorbs moisture out of the air and thereby reduces its boiling point. It can also damage the paint on a vehicle.
Basically DOT 4 has a higher boiling point than DOT 3, so using it your brakes might be more prone to fading.
-Savage- |
Posted: 19:31 - 25 Feb 2006 Post subject: |
Thanks il put some dot3 in for now, until i can get some dot4, then il have a go at bleeding/cleaning/upgrading the brakes when i have time lol ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
JGY6000 |
JGY6000 Trackday Trickster
-Savage- |
Guest |
Guest Brolly Dolly
Posted: 23:08 - 25 Feb 2006 Post subject: |
Thanks for that Keith - copied and saved for elsewhere
why didn't they call DOT 5 something unique like DOT bloody useless? |
Kickstart |
Guest |
Guest Brolly Dolly
Kickstart |
-Savage- |
Kickstart |
mr.z |
mr.z World Chat Champion
Posted: 23:56 - 26 Feb 2006 Post subject: |
Kickstart |
Posted: 00:07 - 27 Feb 2006 Post subject: |
Tried most of the tricks. Use a Mitivac (small vacuum pump) on the bleed nipples. Cracked off the banjo bolts with the system under pressure (both on the m/c and on the splitter on the bottom yoke).
If I pump the lever repeatedly then it builds up some pressure, but that disappears if you leave the lever for a minute or 2. Not sure what the problem is. There is some expansion in the hoses but not much. Maybe enough, but they were not causing problems before (the calipers have been rebuilt with new seals and pistons).
mr.z |
Posted: 00:20 - 27 Feb 2006 Post subject: |
Sounds very odd could you take the whole system off and put it in a tub of water? (ala pushbike tyre? )
I know with coolant systems they use some kind of UV reactive liquid, they put it in the system, pressureise it and then use a uv tube to see where its comeing out... trouble is its bloody expensive (the stuff they use in engineering is anyways), and only usefull if you just happen to have a uv light...
Good luck getting it sorted
BTW how much did it cost to have the calipers rebuilt? did you do them yourself? are they the "floating" kind or the later "pressed from both sides" kind? ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
Kickstart |
The last post was made 18 years, 64 days ago. Instead of replying here, would creating a new thread be more useful? |
