White Noise |
White Noise Mr Dudwee
Posted: 18:04 - 26 Feb 2006 Post subject: electrical problem! arse |
right i am not too sure what is going on, the bike was running fine yesterday, today haven't started it up as wanted to check valve clearances, i did that, now i have put the bike back together there is no power at all! when i turn the ignition on there is no neutral light, no fuel pump engaging, i have checked the battery and its a healthy 12 volts, all the fuses are intact, and as far as i can tell nothing that i have done today would cause a electrical problem, has anyone got any ideas about whats going on, could any of the work i have done to day (removed tank, airbox, carbs, valve cover) cause any electrical problems?
going to do some fault finding now but would gladly like so input
CHeers
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
mr.z |
mr.z World Chat Champion
Posted: 18:10 - 26 Feb 2006 Post subject: |
Chances are its just a multi block has been disturbed or isn't siting it 100% right (so if the neutral light and fuel pump share a common -ground anywhere maybe thats it?)
Personally i'd take all the connectors off and give them a blast with contact cleaner and a wire brush, refit and try again
Have you got a wiring diagram you can post up? ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
Kickstart |
Kickstart The Oracle
White Noise |
Posted: 18:13 - 26 Feb 2006 Post subject: |
sorry the circuit diagram is in the haynes and can't post it, there are 4 fuses in the circuit diagram and on the bike they are all acounted for.
about to started tracing it with a multimeter
White Noise |
Posted: 18:31 - 26 Feb 2006 Post subject: |
found it! it was the mains connector to the ignition barrel and was in a very corroded state! i must have given it a bit of knock when i took the valve cover off!, so glad that it happened at home and not on the road, as had tp take the tank and airbox off to find it!
cheers guys!
White Noise |
Posted: 19:45 - 26 Feb 2006 Post subject: |
honable mention goes to davo for coming over and giving me the right type of spade connector so i could made a good repair instead of a bodge!
post and you'll get the karma!
The last post was made 18 years, 65 days ago. Instead of replying here, would creating a new thread be more useful? |
