Adam_P |
Adam_P World Chat Champion
Posted: 12:30 - 27 Feb 2006 Post subject: Hmm, plastic screws and their faults |
The screen on the Fazer is held in place with five plastic/nylon screws (four across the top, two either side near the mirror stalks) and one under the front beneath the lights.
So, I was giving the bike a bit of a clean the other day and took the screen off to clean behind it and clean around the back of the clocks.
Started to refit the screen and went to tighten one of the left hand screws up and...
the head sheard off, leaving the threaded section deep within the confines of the bike! And no, before you ask, I wasn't screwing it too tight, I was going round them all making sure they were just tight enough. I reckon it was because it was bloody freezing in the garage and they were probably all a bit brittle. Still a pain in the arse though!
I know its not a big deal and hardly merits a spot on the workshop section, but I was just wondering whether any of you had had the same problem before and had any advice on the best way of attempting to getting it out?
Thanks
Adam ____________________ Colin McRae MBE 1968 - 2007 RIP
Orwell Rolls in his Grave
God is imaginary |
EuropeanNC30R... |
EuropeanNC30R... Gay Hairdresser
Kickstart |
Kickstart The Oracle
Adam_P |
Posted: 13:54 - 27 Feb 2006 Post subject: |
Kickstart |
Posted: 14:39 - 27 Feb 2006 Post subject: |
I suspect that if you are careful drilling the you will probably get away with a tiny hole down the middle of the remains of the plastic, and with the remains of the thread undoing as you drill.
Only thing to be very careful about (not so much here, but with metal fairing bolts) is that the fastener can easily get hot enough to melt the fairings when you drill them out.
finpos |
finpos World Chat Champion
Posted: 14:44 - 27 Feb 2006 Post subject: |
Rather than have a go with a drill, I'd be tempted to stab it with a screwdriver you've heated up with a blowtorch or on a hob. Obviously, don't use gramps' bestest screwdriver for the job
Push the screwdiver in a could couple of mm whilst hot and then hold it while it cools. It should then be pretty firmly attached to the stump which will unscrew easily.
If you choose metal to replace the errant bolt with, make sure you use a thickish plastic washer between the head of the bolt and the screen, otherwise the screen might crack - they use plastic there for a reason .
finpos. |
ZRX61 |
ZRX61 Victor Meldrew
numark1 |
numark1 Scared of girls
Posted: 18:51 - 27 Feb 2006 Post subject: |
You can buy replacement screen screws from most bike shops for about £5. |
Jrod |
Jrod Page 3 Girl
ZRX61 |
The last post was made 18 years, 64 days ago. Instead of replying here, would creating a new thread be more useful? |
