matphillipsuk |
matphillipsuk Borekit Bruiser
alains |
alains World Chat Champion
Posted: 17:53 - 28 Feb 2006 Post subject: |
it's only a starter problem or a low (worn) battery
when the battery is worn if the voltage is too low the starter gear will not engage the fly wheel but the motor run . could be also the starter relay which makes bad contact . the frequent bug is inside the starter with worn brushes,brushes springs worn or comutator clogged . download my file https://www.geneva-racing.com/~alains/NSRtips.doc
you will find proceedings to repair your starter , and it's not complicated . if you want indications to take it out , no problem , just ask ____________________ the worst day fishing is better than the best day working |
matphillipsuk |
fuzz |
fuzz World Chat Champion
Posted: 10:48 - 01 Mar 2006 Post subject: |
I had the exact same problem. You will need to take your starter motor apart and clean and relube the gear. When you turn the commutator, the gear should open up and then retract. I suspect it is not opening up and engaging the starter gear. Lots of WD40 and turning the gear should have it working again.
Incidentally, the noise that you can here is the commutator spinning round. So your starter relay is fine, and so are your motor brushes. ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
matphillipsuk |
The last post was made 18 years, 62 days ago. Instead of replying here, would creating a new thread be more useful? |
