| Author |
| G |
 G The Voice of Reason
 Posted: 21:58 - 06 Mar 2006 Post subject: Cheap Roller Garage Doors - Advice needed. -updated- |
Anyone had/used/installed a cheap roller garage door off ebay?
Finally looking to sort mine.
Was looking at something along the lines off a gliderol one linky
Will be fitting it myself, if possible I'll go for the electric option as well.
| Back to top |
| sickpup |
 sickpup Old Timer
| Back to top |
| veeeffarr |
 veeeffarr Super Spammer
| Back to top |
| G |
| Back to top |
| sickpup |
 sickpup Old Timer
| Back to top |
| G |
| Back to top |
| byke95 |
 byke95 World Chat Champion
| Back to top |
| map |
 map Mr Calendar
 Posted: 13:12 - 07 Mar 2006 Post subject: |
Assuming I'm posting this in the correct thread (so may choices, so little time )....
No direct experience but a quick google did come up with this ckicky link on DIY installation.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Back to top |
| G |
| Back to top |
| colin1 |
 colin1 Captain Safety
| Back to top |
| G |
 Posted: 14:25 - 07 Mar 2006 Post subject: |
Shop ones are generally tougher and more expensive I believe.
Was looking for the rolflex ones earlier. A few quid more, but I can collect which should save me money and would be better as I would be looking to do it next week, while others may not be able to deliver by then. |
| Back to top |
| colin1 |
| Back to top |
| G |
| Back to top |
| G |
 Posted: 23:47 - 19 Mar 2006 Post subject: |
Got the Rolflex one in the end.
Had an 'interesting' time fitting it.
All fairly simple (though I didn't bother checking that both sides were the correct height using a 'water level') until we came to the part relating to pulling it down then wedging it open while installing the stops.
See figure c the instructions say. Of course there's no figure c, an 'a' and a 'b', but no 'c'. We try to wedge it anyway, for it loose it's self and unwind a bit.
Four hours of trying to get it wound back and we give up, screwing some wood blocks into garage frame to make it appear shut then pulling my self on elbows under the small opening left.
The next day we get the door off the brackets and lay it on some old blankets to roll it up better. After ten attempts or so we get a good one, so strap it up with tie downs and start again.
This time we don't bother with the chock and get people to hold it down by hand.
We change the order of the installation a bit and get the runners in before undoing the tiedowns. It goes in well enough, so we complete it fairly quickly.
Only other problem was that they managed to not cut the holes for the lock in the rails. This means that you can't leave it down, as it just rolls straight back up.
Eventually I drill some holes in the right place and it all works fine.
Apart from the missing instruction and the hole that wasn't, it was pretty straight forward to install. I didn't do all the precise measuring which they said was important, may have just been lucky it working, though.
Doesn't appear to be amazing for security, but I have other arangements for that and it's better than my old one.
I paid £280 for it, collected. They got it ready in about a week after a bit of hassling.
Much thanks to Goose for sharing the pain, as well as Danny / Dusty / Bendy. |
| Back to top |
| byke95 |
 Posted: 09:28 - 20 Mar 2006 Post subject: |
Good job mates don't charge by the hour eh!
Glad you managed to get it sorted!  |
| Back to top |
The last post was made 20 years, 66 days ago. Instead of replying here, would creating a new thread be more useful? |
