Bling my van - doing up van adviced needed?
PostPosted: 14:28 - 13 Mar 2006    Post subject: Bling my van - doing up van adviced needed? Reply with quote
Been playing about with me 'race van'.
A few questions if anyone knows about such things...
(For anyone that hasn't worked out the title is in jest, it is; I do not intend to purchase 28" chrome wheels, yet.)
I am outfitting it with some basic furniture and trying to make it a bit better to 'live' in, as I probably will be doing for 10% of this year, or so!
Ideally I'd like to ply line it, then fill the gaps between plywood and van with expanding foam for insulation.
However I really need to sort out some decent hooks/rails etc before I do that.
Any reccomendations on ply lining?
Also, was wondering about sticking some carpet straight on the metal walls, would this help insulation much?
As with many ex-builders vans it's been knocked about a bit, especially the doors.
A lot of these don't make great seals with their frames, letting in cold air.
Any easy ways to add in bigger/better seals?
I did try using some home door seal self adhesive strip things, but these weren't really substanational enough and I ended up with them stuck to me, instead of the door!
While we're on the subject - low wattage lighting for the van.
I do eventually want to get a leisure battery for it.
Either way, it'd be nice to have some lower powered lighting. Now that you can get quite bright LEDs, I was wondering about the practicality of this?
Mrs Kickstart
PostPosted: 14:57 - 13 Mar 2006    Post subject: Reply with quote
Hi,
https://www.bltdirect.co.uk/ do low wattage LED strips lights. I have not bought these but have bought other stuff from them.
For the doors would something like the finger protecttors work to keep out some of the draft as well
https://www.safetyassured.com/acatalog/Finger_Protector.html
Regards
C
Help fight the safety camera partnerships Twisted Evil -- www.pepipoo.com
map
Mr Calendar
PostPosted: 15:02 - 13 Mar 2006    Post subject: Reply with quote
Only suggestion I can make regarding ply is go for marine ply. Failing that go for one marked as external use. The reason is it's treated differently and it'll give you a longer life. Believe also it'll be more hardwearing. However, ignore this if going for cheap and chearful.
Thumbs Up Very Happy
Hex
Party Boy
PostPosted: 17:56 - 13 Mar 2006    Post subject: Re: Bling my van - doing up van adviced needed? Reply with quote
I'd look at using something like rockwool from a local wicks type shop mate instead of expanding foam.
Though condensation may become a problem, but I expect your going to have that problem regardless due to little if any ventilation (since you wana stop the cold air getting in).
When you do get to blinging it though it has to have a mirror ball hanging from the ceiling. Thumbs Up
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
daz|n00by
The Internet
PostPosted: 17:59 - 13 Mar 2006    Post subject: Reply with quote
Use 1/8th ply for lining the van walls and attach using self tapping screw's at the van ribs, if you want to carpet the walls first use a cheap foam backed carpet (foam will add to sound proof and insulate) this can be attached by using spray glue for carpets, if you will be fixing hooks or rails on the van walls then before you cover with ply use sheet steel fixed across the van ribs in the area you will be hanging things, this will give you a good grip for self tapping screws.
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
PostPosted: 18:43 - 13 Mar 2006    Post subject: Reply with quote
I'm going to need some quite hefty hooks and such like to hold bikes, which is one reason I haven't done it yet.
It's definitely going to be a 'budget job'.
I've got some thinnish plywood for the job waiting in the garage.
The question about carpet was a too some degree as alternative to plylining etc for the insulaltion properties.
Cheers Charlotte.
Also found some direct replacement LED bulbs on ebay.
kev
I Hump Things
PostPosted: 20:16 - 13 Mar 2006    Post subject: Reply with quote
If you need some hooks made for the floor to hold bikes down give me a yell and i will make some up for you.
Also if your after a leisure battery I can get you one cheap from work with my massive discount.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
kev
I Hump Things
PostPosted: 20:23 - 13 Mar 2006    Post subject: Reply with quote
Another thing you can do if you want to replace the seals cheaply is get some rubber water hose and screw it round where the seal should go, you may have to slam the door to shut it but it will be a tight seal.
msgander
PostPosted: 21:37 - 13 Mar 2006    Post subject: Reply with quote
my own personal suggestion would be a real log fire or failing that some kinda heating.... Laughing
innit...........
Always believe that your guardian angel flies a bit faster than you...............
Hex
Party Boy
PostPosted: 22:02 - 13 Mar 2006    Post subject: Reply with quote
I can just see G's van with a little chimney and portugese style fire/bbq/oven thing, with a spit roasting a pig in the back of his van now. Laughing
sickpup
Old Timer
PostPosted: 01:06 - 14 Mar 2006    Post subject: Reply with quote
Hex wrote:
with a spit roasting pig in the back of his van now. Laughing
This could have at least 2 meanings Laughing
hellkat
PostPosted: 01:18 - 14 Mar 2006    Post subject: Reply with quote
Never underestimate the beneficial effects of zebra fun-fur for insulation purposes.
Low wattage mood lighting can be obtained by the application of rope lighting in multi-coloured chasing stylee.
Cool
tijuana hellkat
Zimbo
PostPosted: 09:06 - 14 Mar 2006    Post subject: Reply with quote
If you've got the room to keep it, for the same money you'd spend on your van, get a cheap (£300 ish) old caravan. That's what we do and it's a LOT more comfortable. Cadwell park in the back of a van in October is cold, no matter how well it's insulated - I know this cos I tried it!!!
PostPosted: 09:45 - 14 Mar 2006    Post subject: Reply with quote
Kev: floor hooks I'm fine with, ta anyway (going to be having 3 bikes in there to start with).
Got an offer of a free leisure battery as well.
Door's are hard enough to close as it is, but I'll keep it in mind Smile.
Sticky: Wanna get a diesel heater, but £££.
Zimbo:
Cadwell in October? Pah, that's tent weather.
Try Snetterton in Feburary:
Just after parking up:
https://www.bikechatforums.com/files/snowynight.jpg
In the Morning:
https://www.bikechatforums.com/files/clearingsnow.jpg
(And yes we did ride that day!)
Anyway, don't have anywhere to put a Caravan, or have a towbar (would have one otherwise Smile ).
sickpup
Old Timer
PostPosted: 12:39 - 14 Mar 2006    Post subject: Reply with quote
Webasto's often turn up in commercial breakers and ebay.
PostPosted: 12:52 - 14 Mar 2006    Post subject: Reply with quote
Yea, been keeping an eye on ebay. Still expensive Neutral.
New prices would be 2/3rd of what I payed for the van!
kev
I Hump Things
PostPosted: 14:46 - 14 Mar 2006    Post subject: Reply with quote
How about a gas caravan heater, you can get them for peanuts.
I may also be able to help you out with diesel, I know a pikey bloke who gets it for me for £90 for a 45 gallon drum (approx £190 worth of diesel in a drum)
map
Mr Calendar
PostPosted: 15:42 - 14 Mar 2006    Post subject: Reply with quote
kev wrote:
...be able to help you out with diesel..a pikey bloke...£90 for a 45 gallon drum...
Not 'red' is it? Wink Very Happy
kev
I Hump Things
PostPosted: 16:56 - 14 Mar 2006    Post subject: Reply with quote
Nope its proper white.
The last post was made 20 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 106.04 Kb
