Front Brake Problem
Foosoup
PostPosted: 21:33 - 23 Mar 2006    Post subject: Front Brake Problem Reply with quote
Hi all,
Just wondering if anyone can help me. I recently fell off my CBR600 F-W and now have a problem with the front brake.
Basically there is a strange grinding type sound coming from the right hand brake section i have totally removed this and cleaned it all and made sure the pads are clean and that the disc is smooth and not damaged. Does anyone have any idea what this could be?
Thanks
Andy
Bezzer
PostPosted: 22:27 - 23 Mar 2006    Post subject: Reply with quote
Have you checked everything is running true?? Tape a pointer to the fork leg nearly touching the wheel, spin it and see if it's running out, then move the pointer and put it to the discs and check them the same way then at least you'll know if anything is out.
Are the fork legs twisted a bit from the fall?, worthwhile taking the wheel off, slackening the fork leg clamps then doing everything up again.
Rookie
PostPosted: 22:30 - 23 Mar 2006    Post subject: Reply with quote
Check that one of your pads hasn't worn partially down to the metal as well. Mine had the grinding noise you're describing, all it needed was a new set of pads.
The last post was made 19 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.19 - MySQL Queries: 14 - Page Size: 34.8 Kb
