any java programers out there?
c-2501
PostPosted: 00:03 - 05 Apr 2006    Post subject: any java programers out there? Reply with quote
ok basicaly the problem is this;
i have to create a java program that will access and run the URL of a script the way puting the url into a web browser would
heres what i have so far:
Code:
import java.net.*;
import java.io.*;
public class main{
   public static void main(String[] args){
      try{
         URL light1 = new URL("http://<IP goes here>?<path>\\<path>.<blah>?ea2_1");
         URLConnection light1connection = light1.openConnection();
       catch (MalformedURLException e) {
       System.out.println("bad URL");
       catch (IOException e) {
          System.out.println("bad connection");
the prog compiles without errors and seems to be properly opening the connection, im unsure where to go from here though, as the script does not seem to be run by this code alone.
any ideas what im missing here Question
I am, therefor I are!
Mrs Kickstart
PostPosted: 19:17 - 05 Apr 2006    Post subject: Reply with quote
Hi,
You need to set up the http connection, I have some code that does it but I am not at work until Monday. I post it then if you are strill stuck
Regards
C
Help fight the safety camera partnerships Twisted Evil -- www.pepipoo.com
c-2501
PostPosted: 20:46 - 05 Apr 2006    Post subject: Reply with quote
thanks, glad someone replied.
heres a better example url https://xxx.xxx.xxx.xxx/cgi-bin/camctrl.cgi?move=left
sorry to nag, but i need this kinda urgent, could you post a link to a useful tutorial or something, its difficult to search when your not sure what your looking for :/
Mrs Kickstart
PostPosted: 13:40 - 06 Apr 2006    Post subject: Reply with quote
Hi,
Here is a version of the code but not the final copy, I cant get that till next week but I think this worked it is slightly different between HTTP and HTTPS. _repsonse has the page in it
HTH
C
c-2501
PostPosted: 16:12 - 06 Apr 2006    Post subject: Reply with quote
it worked \o/ thanks you know how many java forums i posted on and didnt get a responce nearly as good as this
i might actually have a chance of passing this module now Very Happy Thumbs Up
Mrs Kickstart
PostPosted: 17:51 - 06 Apr 2006    Post subject: Reply with quote
Hey.
If I doing your homework handover over bribes Laughing
Its not a well documented feature, to get it working in HTTPS it took a few days of playing but it has been useful code since.
I am usually to idle to read the instructions and mess, my boss read the instructions but wont mess, we kind balance each other out.
Hope you do pass, what are trying to do ?
Regards
C
c-2501
PostPosted: 18:52 - 07 Apr 2006    Post subject: Reply with quote
its a crappy uni project, i have to build a control panel for a 'smart house' connected to the internet.
but judging by the job ive done im going to have the pleasure of doing it all again next year when im forced to retake the whole year Sad
The last post was made 20 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 0.94 - MySQL Queries: 14 - Page Size: 52.58 Kb
