F Drive Problems
freestyler_onli
PostPosted: 00:21 - 09 Apr 2006    Post subject: F Drive Problems Reply with quote
G'day guys.
Im having problems connecting my MP3 stick into my F Drive.
It's literally a case of sticking it in and pulling it out until i see the connection is made. I have to do this maybe 30 times- why does it not register every time???
Could it be to do with firewalls etc....
Ta.
T1z3R
PostPosted: 13:44 - 09 Apr 2006    Post subject: Reply with quote
i wouldnt imagine your firewall would affect this but PCs are mysterious beasts.
i assume its a USB mp3 player? are you connecting it direct to a USB port on the PC or into a USB hub of some sort?
duck my sick!
freestyler_onli
PostPosted: 15:58 - 09 Apr 2006    Post subject: Reply with quote
Its into a USB Hub but there are other things init which always work. Confused
BFG
PostPosted: 17:11 - 09 Apr 2006    Post subject: Reply with quote
Why F: ??
Windows has very funny ideas about allocating drive letters.
Set your spare hard drives, network drives and optical drives higher up the alphabet.
Then let your pen drive connect as D:
Should help. Smile
freestyler_onli
PostPosted: 17:32 - 09 Apr 2006    Post subject: Reply with quote
It cant: I have 2 disc drives which are D: and E:.
Hmmm.
T1z3R
PostPosted: 18:48 - 09 Apr 2006    Post subject: Reply with quote
plug it straight into a USB port as a test.
duck my sick!
simon1221
PostPosted: 19:40 - 09 Apr 2006    Post subject: Reply with quote
Then try it in another PC to see whether it is the MP3 player
DNA50 (sorry) ->> TZR125l >> GPZ500S
freestyler_onli
PostPosted: 17:18 - 13 Apr 2006    Post subject: Reply with quote
I tried it in my laptop which worked fine no worries- ill try the usb port and see what happens.
veeeffarr
PostPosted: 17:22 - 13 Apr 2006    Post subject: Reply with quote
Can't believe no one has asked whether it's USB1.1 or USB2.0 yet, or what O/S he's running?
If you're running Win98, USB is like that, it's shit and unreliable on 98.
If it's a 2.0 unit and you're running on 1.1 on your computer, then again, it's not that reliable.
If it's 2.0 running on 2.0 then check your USB ports for fluff/damage, the plastic pins inside the ports can snap off and cause all sorts of trouble.
divuk83
PostPosted: 17:38 - 13 Apr 2006    Post subject: Reply with quote
My MP3 player doesn't work properly through my usb hub, however it works perfectly when I connect it to the ones on the back of my PC, Strange, but its worth a try.
Dave
freestyler_onli
PostPosted: 09:57 - 14 Apr 2006    Post subject: Reply with quote
Yes it does work when conencted direct. Ta for the help guys. Cool
T1z3R
PostPosted: 15:46 - 14 Apr 2006    Post subject: Reply with quote
glad its sorted mate.
check if your USB hub is host powered or not cos it sounds like there wasnt enough power to run the MP3 player through it as well.
duck my sick!
The last post was made 18 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.92 - MySQL Queries: 17 - Page Size: 71.13 Kb
