 Posted: 21:27 - 14 Apr 2006 Post subject: It's in |
Got that GPZ500 engine in the KLE and running today. Started fitting it at 12.30 today, just got back inside after a brief test-ride.
Actually managed to lift the engine in by hand and balance it there while I slid the bolts home.
The CDI wasn't too tricky to wire in either although as it turns out, the coils are the opposite way round. Had the ignition timing 180 degrees out on the first attempt, just a case of swapping two connectors round though.
Other buggeration factors were pretty minimal. I accidentally left the o-ring off the old oil filter on the e4ngine and put the new one on top of it with the net result that the bike spat out about 2 litres of oil in a second when I blipped the throttle. At least there are no worries about the oil pressure.
It isn't running right, but it is doing exactly the same as the KLE was when I put the same set of carbs on. Pulls like a train up to 7k hesitates, pulls through then totally runs out of steam at about 8k. I'm convinced it isn't getting fuel, not sure if it is a problem with the carbs themselves or if the fuel just isn't running out of the tank quickly enough.
I'll put the KLE carbs on it tomorrow and have another tinker with the GPZ ones. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| colin1 |
 colin1 Captain Safety
| phantomtek |
 phantomtek Lil Joe Tek
 Posted: 00:39 - 15 Apr 2006 Post subject: |
Good job Stinkwheel.
| Paul@125power |
 Paul@125power Could Be A Chat Bot
 Posted: 02:19 - 15 Apr 2006 Post subject: |
I had the same problem when experimenting. I found that thinking in of term of not enough fuel was wrong..think of in terms of air!
By this I'm no trying to by condescending
I just have moral thought about teaching and learn ____________________ If at first you don't succeed.....destroy all evidence that you tried.
Yamaha YQ100 (RIP)......Honda CBR125R |
| quacker_boy |
 quacker_boy Cuddle Bitch
| carlnicholson... |
 carlnicholson... World Chat Champion
| Richy |
 Richy Nova Slayer
 Posted: 13:01 - 15 Apr 2006 Post subject: |
According to the book, a KLE makes 50bhp and a GPZ500 makes 60bhp. One always has to take what the Japanese claim their bikes do with a pinch of salt though, they are notorious for lying about it.
That said, having ridden both, the GPZ is certainly a lot more peaky, revs higher but with a much flatter midrange.
Laser make a 'pro-duro' stainless exhaust system for the KLE with a choice of either a road legal or a sports can. I got the sports can which sounds great, but it is rather noisy. I know I have no problems with the MOT because the guy that does my testing has exactly the same can on his bike, others may not be quite so impressed. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| carlnicholson... |
 Posted: 13:45 - 15 Apr 2006 Post subject: |
It's the emissions I'll have bother with I think. Getting rid of all the cats would give it much more shove, but may pose problems for it's first MOT. It is 2 years away, but I will almost certainly still own it then.
Bloody europe sticking their beaks with emissions.  ____________________ "THOSE WHO RISK NOTHING, DO NOTHING, ACHIEVE NOTHING, BECOME NOTHING." |
| impaler |
 impaler Crazy Courier
 Posted: 13:53 - 15 Apr 2006 Post subject: |
Correct me if I'm wrong, but I thought there was no emissions testing for a bike MoT? Volume is another problem altogether, of course. ____________________ Monster m600
Web, blog, Bikepics page
An optimist will tell you the glass is half full. The pessimist, half empty. The engineer will tell you the glass is twice the size it needs to be. |
| carlnicholson... |
 Posted: 13:59 - 15 Apr 2006 Post subject: |
There is no emissions testing as yet as the bikes built to the EURO regs have not yet reached 3 years old to need a MOT.
It doesn't affect older bikes, just those built after the regs came in. IE mine in 2005. Bastard.  ____________________ "THOSE WHO RISK NOTHING, DO NOTHING, ACHIEVE NOTHING, BECOME NOTHING." |
 Posted: 15:29 - 15 Apr 2006 Post subject: |
| Richy wrote: |
Just a thought, is it not possible to drill another sump plug hole then tap it and abandon/weld the other bolt in place (prob wont come out anyway)  |
Nah, it's the brass drain screws in the bottom of the carb. They are tapered at one end and open a valve when you loosen them off which allows fuel to run out of a spout in the bottom. You can measure the float height by putting a length of clear tubing on the spout and holding the end up alongside the carb. The fuel runs into the tubing up to the level it is sitting in the carb.
| Quote: | It's the emissions I'll have bother with I think. Getting rid of all the cats would give it much more shove, but may pose problems for it's first MOT. It is 2 years away, but I will almost certainly still own it then. |
Given my experience with the quality of standard, mild steel Japanese exhuausts. I think it is highly unlikely that your original system will be in any fit state to perform its function after three years anyway. You can always take it off, put it somewhere safe, fit a stainless system and put the original back on for the MOT.
Anyway, in the spirit of experimentation, Itried it with the airbox off. Runs like a bog of shite, wont run at all above 5k. That kind of confirms that the airbox size/shape makes a huge difference to the carburettion and that the GPZ carbs are simply not set up to run on a KLE airbox (I compared them, the GPZ airbox is easily double the size). The inlet stubs are also a fair bit longer on the GPZ setup, I know this makes a big difference with 2-strokes so perhaps the same thing is happening.
I've put the KLE carbs back on and it pulls a lot better than it did with the standard engine. Also seems to have cured the problems I was having with it running rich through the sports exhaust, no more popping on the over-run.
Well pleased, I am off to have a play on the A7 then go and get pissed with my brother up in Edinburgh. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| carlnicholson... |
| byke95 |
 byke95 World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 14:23 - 16 Apr 2006 Post subject: |
so in essence you've built a post 2002 KLE500? , as new KLEs use old GPZ500 engines don't they? ,
good job though , never dare do it meself only the basics  |
| carlnicholson... |
The last post was made 20 years, 189 days ago. Instead of replying here, would creating a new thread be more useful? |
