probably a daft Q...
rpg
PostPosted: 20:12 - 17 Apr 2006    Post subject: probably a daft Q... Reply with quote
sorry to post this, but i want to turn up to my test lesson at least with some idea of how to do this properly.
Ok set scenario.....i am approaching a red light, need to slow down, do i use brakes and change down gear as i brake........or change down gears and then brake?
Sorry if this seems trivial, i have only ridden a moped.
many thanks! Smile
Whosthedaddy
PostPosted: 20:24 - 17 Apr 2006    Post subject: Reply with quote
Either Wink
Arrow Se the rde light, start to change gently through th gears, so if they turn green you are in the correct gear to pull away Thumbs Up
or
Arrow As you brake for the red light, quickly downshift through the gears as you are about to stop.
The latter may mean that you are 'coasting' with the clutch pulled in for longer than the first.
Rob W
PostPosted: 20:29 - 17 Apr 2006    Post subject: Reply with quote
Change down the gears as your braking to match your engine speed, that way if the light goes your in the correct gear to pull away again smoothly. It's also a good idea to blip the throttle slightly as you change down the gears.
Groove
PostPosted: 21:04 - 17 Apr 2006    Post subject: Reply with quote
Not needed on test though Thumbs Up
Villers
PostPosted: 23:15 - 17 Apr 2006    Post subject: Reply with quote
On a safety note, although not sure how this applies to the test, it may be a good idea, when using the gears to slow down to a standstill, that you pull the front brake lever enough to illuminate the rear light. This way the dozy commuter in his mondeo knows you are slowing down and not just getting bigger!
Whosthedaddy
PostPosted: 23:17 - 17 Apr 2006    Post subject: Reply with quote
The examiner will get pissed off if you keep engine breakng and not using the actual brakes to slow down for junctions or round abouts
Itchy
PostPosted: 23:36 - 17 Apr 2006    Post subject: Reply with quote
whatever you decide to do on a test pull in the front brake a tiny bit so that the brake light comes on such that even though you might not be using your brake it looks like you are doing it,
good advice anyway I reckon , since with correct freeplay on the brake lever you should be able to pull it in without braking and showing the brake light anyway.
this is HIGHLY useful when being chased by irritate BMW drivers , they think you are slowing so they brake hard thinking if they don;t they'll go through you and kill you , while you continue at the same speed.
Whosthedaddy
PostPosted: 09:57 - 18 Apr 2006    Post subject: Reply with quote
Whistle Laughing Thumbs Up
The last post was made 20 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 58.72 Kb
