Carpel Tunnel Syndrome
Rookie
PostPosted: 18:59 - 06 May 2006    Post subject: Carpel Tunnel Syndrome Reply with quote
Basically, I've got a slight tingling in my right hand, middle 3 fingers.
https://www.netdoctor.co.uk/ate/musclesjoints/203617.html
So it's carpal tunnel syndrome, I reckon. I'm wondering whether it's bike riding that's likely to have caused this? When I ride the bike, I often feel the need to 'shake out' my hand, to get rid of the numbness.
Any insights/ideas?
Flip
PostPosted: 23:39 - 06 May 2006    Post subject: Reply with quote
My dad this. Had to have an operation. Still debating wether to have the other hand done.
Do a search it on here somewhere.
Flip
PostPosted: 23:42 - 06 May 2006    Post subject: Re: Carpel Tunnel Syndrome Reply with quote
Just noticed this sentance. It's for the specialist to say not you. Wink Net diagnosis cant be the best. Karma
yambabe
PostPosted: 23:57 - 06 May 2006    Post subject: Reply with quote
You are more likely to have Vibration White Finger.
Carpal Tunnel Syndrome usually affects the thumb and wrist rather than fingers IIRC?
Itchy
PostPosted: 00:47 - 07 May 2006    Post subject: Reply with quote
go see a doctor , get a diagnosis then see another for a second or third opinion , and thank your lucky stars we live in the UK where the surgery is paid for already.
Rookie
PostPosted: 11:19 - 07 May 2006    Post subject: Reply with quote
The other likely possibility is pressure in the wrist. The nerves to the fingers go through a small tunnel at the wrist to get into the hand - called the carpal tunnel. Pressure here will produce similar symptoms. Usually it is the middle fingers that are most affected. It can be worse at night and cause pain or discomfort that may wake you, or the hand may feel particularly numb and heavy first thing in the morning. This condition is called carpal tunnel syndrome.
There are usually no serious reasons for these symptoms. Nevertheless, it would be sensible to tell your doctor about them, so he or she can confirm the likely cause and advise you about treatment if that becomes necessary. This may be the case if the symptoms do not soon settle on their own.
I will be going to a doctor anyway, but wondered what people knew on here. Is there any form of treatment aside from surgery, as I don't want the condition to worsen. Confused
DucatiEVO
PostPosted: 11:56 - 07 May 2006    Post subject: Reply with quote
Go see your doc, I had a problem like this when I first started riding, half my hand went numb Shocked , was like it for about 6-8 weeks and gradually got better.
Things I did to improve this was adjust my riding position, lever position, clutch lever pressure, heavy bar weights (reduce vibes).
Also the type of bike you ride can have a large effect, sportsbike riders tend to suffer from this more with the increased load on their wrists.
I think if you actually had full blown CTS, it would be a lot worse than it is. Taking some of the steps mentioned above should help solve your problem.
P.S When you brake, try and use your legs on the tank to help support your body, rather than let your arms take the strain (it loads up your wrists).
aKa: Ducky
Handsome
PostPosted: 12:06 - 07 May 2006    Post subject: Reply with quote
A woman I know has just been diagnosed with this and she's put it down to too much Wanking..... Clapping Drooling Thumbs Up
BorderHooner
PostPosted: 17:44 - 15 May 2006    Post subject: Reply with quote
I used to do a lot of brick face cleaning etc using high pressure H20 jets.
I also used to do a lot of heavy manual stuff with my hands and have had a few sharp hard knocks to my wrists and elbows.
I stopped doing it about 2 years ago and do as little as I can manually.
If I do anything heavy with my hands, I wake up with numb hands and pains in the joints of my wrist and elbows.
long journeys on the bike are made easier by loosening right off with the grips and just cupping the throttle, also sitting more upright and not putting weight on the wrists.
if it is carpel tunnel then your looking at either keyhole surgery to the wrists or open surgery. neither is proven 100% effective.
white finger is completely irreversible, although you can use massage techniques and essential oils to ease it a bit.
I just live with it.
Benelli. Happy as a pig in cacky.
The last post was made 20 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 62.14 Kb
