Geforce 4 MX440 blurred - HELP I'm going blind
John C
PostPosted: 23:14 - 08 May 2006    Post subject: Geforce 4 MX440 blurred - HELP I'm going blind Reply with quote
I building up a second system for someone out of all the spare parts I've got lying around.
All was going well untill I dropped a Nvidia Geforce 4 MX 440 128MB card into it.
At any screen res above 800x600 It blurs on screen fonts to the point it's hurting your eyes after 30 minutes.
If I turn the refresh rate down to 60hz I can use 1152x864 without the blurring, but I get the dreaded flicker which is twice as bad.
I've tried the latest drivers (and the 2 before). Same thing!
Any suggestions (please, mine eyes can't take it any more)
Thanks
J
djr
PostPosted: 23:16 - 08 May 2006    Post subject: Reply with quote
https://www.ebuyer.com/UK/product/86747
djr
PostPosted: 23:17 - 08 May 2006    Post subject: Reply with quote
John C
PostPosted: 23:19 - 08 May 2006    Post subject: Reply with quote
So good you posted it twice Laughing
Thanks but not quite what I was looking for.
anyone else (there's karma in it for ya Karma Wink )
djr
PostPosted: 23:34 - 08 May 2006    Post subject: Reply with quote
Indeed, something went wrong, wasn't expecting anything to be posted atall TBH
craigie b
Citizen Smith
PostPosted: 23:41 - 08 May 2006    Post subject: Reply with quote
the card could be fecked, their manufacteured in such large numbers and their so low budget...I seen some for sale for like £7 last week.
John C
PostPosted: 00:03 - 09 May 2006    Post subject: Reply with quote
I'll look into it, but I'm not finding much...
https://www.google.co.uk/search?hl=en&safe=off&q=nvidia+MX+440+blurred&meta=
Jamie.
PostPosted: 11:03 - 09 May 2006    Post subject: Reply with quote
One of two things:
1) Your card is F**ked
2) Your using the wrong drivers
You said youve tried many drivers? There is only one driver for your card and its the same driver that all geforce cards use. Make sure your downloading it from www.nvidia.com, Infact
https://www.nvidia.com/object/winxp_2k_84.21.html
Thats the right one, Make sure you uninstall any drivers thats on your system now, Reboot then install the new ones, reboot again and it should be fixed. If not, then the card is buggered
John C
PostPosted: 13:34 - 09 May 2006    Post subject: Reply with quote
-Jamie- wrote:
One of two things:
Thanks, I think the card may be shot.
As for the drivers, I was indeed referring to the forceware drivers that cover all geforce cards.
You can download all previous versions from Nvidia as well as the current release.
I've tried several (no joy).
craigie b
Citizen Smith
PostPosted: 14:54 - 09 May 2006    Post subject: Reply with quote
switch the card out with another g/card that way you'll at least be able ensure that Its not the motherboard or connections to your monitor or its not the software you have on your machine
its a good way of eliminating possible issues before shelling out for a new gcard.
Lawnie
PostPosted: 15:34 - 09 May 2006    Post subject: Reply with quote
Are you running Windows XP? There's all kinds of problems with modern video cards operating at over 60Hz, for which I'm pretty sure there is a patch.
Lawnie
PostPosted: 15:38 - 09 May 2006    Post subject: Reply with quote
Also check your version of Direct X.
This also might be of interest: Click!
HTH
John C
PostPosted: 16:20 - 09 May 2006    Post subject: Reply with quote
Done it already swapped for an old 32MB hercules.... It's definitely the card not the mobo.
Tell me about it, it's fine (not blurred) at 60Hz, but the flickering is toooooo painful on the old retinas. I can't give that to someone.
Ohh, I'm on 9.0b, I see there is a 9.0c out Thumbs Up
I'll go play and report back
Cheers all Thumbs Up
Jamie.
PostPosted: 16:38 - 09 May 2006    Post subject: Reply with quote
Have you tried putting the borked card into another computer? that way you will know if its drivers conflicting
John C
PostPosted: 16:46 - 09 May 2006    Post subject: Reply with quote
yes, and it's still blurred.
I'm hoping it could be a driver/win XP issue as these and the card are the only things common to both systems.
no_shad
PostPosted: 18:46 - 09 May 2006    Post subject: Reply with quote
Have you tried using 1024x768 @ the highest refresh rate you get away with. Probably 85Hz?
John C
PostPosted: 18:53 - 09 May 2006    Post subject: Reply with quote
That works ok but over the past year I've got used to 1152x864 (on a 19") and 1400x1050 (on a 21").
For me, 1024x768 would be like you using 640x480.
Thanks for the thought all the same. Thumbs Up
Lawnie
PostPosted: 21:12 - 09 May 2006    Post subject: Reply with quote
I'm not surprised!
My 21'' monitor operates at 1280x1024, and that's probably the equivalent of 1024x768 on a 17''.
John C
PostPosted: 21:25 - 09 May 2006    Post subject: Reply with quote
I think this card must be on it's last legs. I've found an old ATi Radeon 9200 128MB in the loft though so that should do the trick.
Thanks. Thumbs Up
mattfuzzy
PostPosted: 01:15 - 10 May 2006    Post subject: Reply with quote
for the record i skipped past almost all of this thread other than about the first few posts, i prefer ATI for one... i also prefer newer and faster tech (and yet the only reason y im still stuck on my 1,768mb ram, ati 9800pro atlantise is because im poooor as hell, should get a new 1 sometime soon i spose even tho i get good fps in bf2... the geforce is prob screwed as anything wrong with the graphics or blurred/distorted graphics (most the time in games) or for example i was see'ing florescent colours in cs 1.6 when my allinwonder overheated and fried partly... Mr. Green
Fadel
PostPosted: 21:22 - 10 May 2006    Post subject: Reply with quote
Font smoothing, I had it once just can't remember how I turned it off Laughing few years back.
Pretty sure it was that anyway.
John C
PostPosted: 10:59 - 11 May 2006    Post subject: Reply with quote
It wasn't that, the card was shot
I know what you mean though...
Visual effects>
smooth the appearance of on screen fonts.
tribal_tiger
PostPosted: 12:35 - 11 May 2006    Post subject: Reply with quote
Lay off the wanking for a few weeks
How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it.
The last post was made 17 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.71 - MySQL Queries: 17 - Page Size: 120.43 Kb
