Gazdaman |
Gazdaman I did a trackday!!!
djr |
djr World Chat Champion
ph1l |
ph1l Borekit Bruiser
Posted: 20:22 - 09 May 2006 Post subject: |
Plug it in but make sure the jumper for the new HDD is set to "slave" and the HDD with XP on set to "master" Then when you boot up go to my computer and the new HDD should be there (next to C drive) right click and press format, when done you sould be able to use it as extra storage
Hope this helps |
Jamie. |
Jamie. World Chat Champion
Posted: 20:26 - 09 May 2006 Post subject: |
hi there. get the hard drive in your hands with the power board at the bottom (with the label on top) get a jumper, if you dont know what they are its a small clip type thing that slots over 2 pins
Now, put it on so it looks like this
Do the same do BOTH hard drives, plug your master (the one its gonna boot to) at the end of the cable, and your new one on the middle connecter of the IDE cable
Then, once your booted up and its hopefully picked up the new drive (can sometimes take over a minute to even pick it up)
Go into "My Computer" where you should see the new drive
Right click it and select "format" You might want to do a quick format, this is fine if the drive is newish
You can then rename it to whatever you wish, eg: "Storage"
Have fun |
djr |
Posted: 20:47 - 09 May 2006 Post subject: |
-Jamie- wrote: | hi there. get the hard drive in your hands with the power board at the bottom (with the label on top) get a jumper, if you dont know what they are its a small clip type thing that slots over 2 pins
Have fun |
What a load of shite... the jumper position depends entirley on the manufacturer of the hard drive... |
ph1l |
Posted: 20:58 - 09 May 2006 Post subject: |
djr wrote: | -Jamie- wrote: | hi there. get the hard drive in your hands with the power board at the bottom (with the label on top) get a jumper, if you dont know what they are its a small clip type thing that slots over 2 pins
Have fun |
Beat me to it, some need no pin to be master and some need no pin for cable select,
It will say on the label which is which or it might have:
M for master
S for slave
CS for cable select
and can't remember last one/if there is one
Engraved above each 2 pins |
Gazdaman |
The last post was made 17 years, 358 days ago. Instead of replying here, would creating a new thread be more useful? |
