An interesting article about Countersteering...
veeeffarr
PostPosted: 15:57 - 18 May 2006    Post subject: An interesting article about Countersteering... Reply with quote
https://www.superbikeschool.com/images/no_bs_bike_top_320.jpg
See it in action
The Correct Brothers
It shouldn't be alarming to me that riders still question how to steer their motorcycles but it is. Apparently, even after 90 years when it was first observed by the Wright brothers some confusion remains on this subject . Yes, their first engineering attempts were as bicycle manufacturers; the very observant brothers determined that tandem (one wheel in front of the other) wheeled vehicles counter steer. That was and still is correct.
Sources Of Confusion
It is easy to see how confusion arises on the subject of steering for anyone of us who started their riding on pedal bikes. The steering is so light on a bicycle that riders have difficulty in separating the shift of their body mass (leaning into it) with the slight effort it takes to countersteer.
Further confusion arises from word of mouth advice on riding. I have even seen articles in usually credible national magazines extolling the virtues of body mass type steering. Body Steering as it is called. I have surveyed thousands of riders on this point. Most riders still believe that some of the steering is being done with their body mass or weight shift or pressure on the motorcycle's tank or pegs. Their estimates on how effective these are in getting the bike to turn range anywhere from 10% to 90%, some believe all of it is weight shift.
Swoopy Steering
If it weren't so grim, it's almost comical to watch a rider who does not understand how steering is accomplished. You can see them riding down the freeway trying and failing to change lanes by body steering and still appear cool while doing so. I have seen it dozens of times. It goes like this. The rider does a very swoopy upper body swing in the direction he wishes to go but for an agonizing (to me) moment, nothing happens. There is a perceivable lag between the upper body swoop and the bike's deflection from its original course. How terrifying it must be to find that the bike doesn't instantly respond.
Stiffen To Steer
Following that is a stiffening of the rider's upper body. Only then does the bike respond and change lanes. You see how this works? The rider's body is positioned off-center, from his swoop, in the intended direction of the lane change. The stiffening on the bars creates the countersteering action, because he has either pushed on the inside bar or stiffened and pulled on the outside one or a combination of both. This stiffening is actually a mild panic reaction. Many riders have simply learned to live with the lag and to think it is how their bike handles. That is false, a motorcycle responds almost instantly to countersteering.
Vague Technique
Riders have a number of ideas, which are vague and hard for them to describe, on just how their weight shifting accomplish this so called body-steering. "Throwing" their upper body mass to one side or the other (the swoop) is one. Some say they just push down on the inside peg. Some say they pull the bike over with the outside leg against the tank. Some say it is a combination of two or even all three of the above methods. Do they work?
I'll leave it up to the tech boys to figure out the WHY of motorcycle counter- steering. Their job should be to provide a simple demonstration of how it works. The fact is that countersteering is still being argued in the halls of learning with slide rules, Physics formulas and calculators. Many theories exist but no conclusive statement that I know of as to why has yet been reached. Argue on boys.
Clear The Issue
My job is to make riding simple and to clear up conflicting information that a rider may have on the subject of riding. Any confusion translates into reduced control, as in the lag from swoop to lane change, and confidence, as in the bike won't do what I want it to, when I want it to. Riders don't like the uncertainty and love the feeling of confidence. I decided to clarify this steering issue, body vs counter, very simple and very plain. I reasoned that anyone who could see how it works and experience the real steering procedure would have dramatically improved their chances of survival against the perils of 21st Century Earth street riding. Steering must be done and done quickly if a rider has any hope of confidently neutralizing those perils.
Expert Opinions
I was actually in a deep confusion on this subject of body-steering myself. Riders the caliber of Eric Bostrum have told me that they do it to some degree, to help steer. Freddie Spencer has made a statement to that effect and of course Reg Pridmore has made it the banner for his CLASS schools for 15 years. Jason's STAR school has been written up as teaching body steering as well.
With great to good credentials like that it should be so, and even I was a little shaken in my certainty. Maybe there was something in it after all. I hate to miss anything.
The Experiments
For my part, experimenting with pressure on the pegs, the tank, adjusting my body mass and combinations of all three on the bike resulted in nothing I would consider steering. In other words, something that could be used in an emergency maneuver or to aggressively flick the bike into a corner or through a set of esses.
Eventually I arrived at a potential solution to my questions that would eliminate my opinions and/or misunderstanding on the subject.
The Solution
Make a bike that has two sets of bars. One set as normal, the other set would be solid mounted to the frame so they were not connected to and did not rotate the forks. This, as my theory went, would answer the question. And it does.
The Machine
Taking one of our Kawasaki ZX 6Rs and solid mounting a set of bars 8" above the standard ones would positively isolate the various body shifting from the countersteering. If body-steering had any effect it would be simple to show it. I created a bike with that setup. One necessary detail was to mount an additional throttle on the upper, solid mounted, bars so the bike's stability could be maintained as the user rode down the road. So we wound up with two sets of handlebars and two operating throttles on the bike.
Dirty Exceptions
Before I go any further I want to address off-road motorcycles. An off-road motorcycle will easily steer by pressing down on the inside peg, and in conjunction with shifting the upper body mass, will go over pretty easily . Still not what I would call good control but it can be done fairly efficiently.
Again, I am not a true tech guy but it occurs to me that the small contact patch on knobbies or dual sport tires and dirt bike steering geometry, which is not intended to provide an enormous amount of stability at speed, contribute to the reasons why steering results from weight shifts to the degree it does on a dirt bike.
No B.S.
At this writing, we have run nearly 100 riders of all experience levels on this double barred bike. It has made believers out of every single one--in the actuality of countersteering of course. Even at speeds of no more than 20 to 35 mph, no matter how much you tug or push or pull or jump around on the bike, the best we saw was that the bike wiggled and became somewhat unstable. Did it turn? Not really. Would it turn at higher speed? Absolutely not. Could you avoid something in your path? No Way. Could anyone quick turn the bike? Hopeless! The best result was one of my riding coaches. He got into a full hang-off position and was able to persuade the bike, by jerking on it, to start on a wide, wide arc in the paddock at Laguna Seca, a piece of asphalt that is about 500 X 800 feet. Like turning an oil tanker ship, start at noon and be on the turning arc at around 1:00 PM. It wasn't smooth and it wasn't very effective.
We now call this bike "The NO BS Bike". There are no doubts in anyone's mind after they ride it that they have been countersteering all along. No doubts.
You can hear riders, who believed in the body-steering method, laughing in their helmets at 100 yards away once they get those solid mounted bars in their hands and try to body-steer the bike. They just shake their heads. No B.S.
Dangerous Misconceptions
Now if you want to look a little further into this, what you will see is this; riders who still labor under the misconception that they body-steer are devoting themselves in a system that can do a great deal of actual harm. Firstly, it is seriously misguided to add an additional series of actions to the steering process. When it is quick, critical steering that is needed to avoid something, that lag I have observed so many times in street riders, could cost you your hide.
Adding 2/10ths to 5/10ths of a second, or more, to the steering procedure at 60 mph means that you have just gone another 18 to 44 feet, or more, down the road before you started to avoid that muffler lying in your path. Kids, don't try this at home.
The way things are going there will be warning labels on motorcycles in the not too distant future.
WARNING: THIS VEHICLE COUNTER-STEERS. IF YOU DO NOT UNDERSTAND COUNTERSTEERING DO NOT RIDE. SEEK THE HELP OF A QUALIFIED PROFESSIONAL Riding Coach.
Bull Steering
Another recognizable error, resulting in excess effort used to steer the motorcycle, is the attempt to turn the bike by bulldogging the bars. An interesting combination of pulling up on one and pushing down on the other rodeo style, like bull wrestling. No, repeat No, steering results from this. None, zero, nadda, niente. Riders who think they can twist the bike into a turn in this fashion simply have another false idea and get tired. The Bottom Line
Steering a motorcycle results from the process of pushing the inside bar forward, the same angle and direction the forks rotate in the steering head bearings. You can also pull on the outside bar. You can do both push and pull. That is what turns it, that is all that turns it with any degree of accuracy, efficiency, quickness or smoothness. That and only that, No B.S.
Copyright www.superbikeschool.com
Dark
PostPosted: 16:03 - 18 May 2006    Post subject: Reply with quote
I'ne not seen that article before, nice find mate Thumbs Up
My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
KR1S 250 / Kawasaki ZXR750 H2 / Honda C50 / Kawasaki ZX7R P5 / Kawasaki ZX10R / Suzuki GSXR 400 / Honda CBR1100 Blackbird & Yamaha FZR 600
Keen
PostPosted: 18:23 - 18 May 2006    Post subject: Reply with quote
link doesn't work for me and I'm interested in reading it... any chance you could copy and paste the text?
cheers Thumbs Up
PostPosted: 18:40 - 18 May 2006    Post subject: Re: An interesting article about Countersteering... Reply with quote
Toby R wrote:
So next person that goes on about KD to me can eat my shit. Very Happy
Article's not loading, but I doubt there's many people that claim that getting your knee down helps change the angle a bike is going.
veeeffarr
PostPosted: 18:49 - 18 May 2006    Post subject: Reply with quote
Aye, was just messing.
veeeffarr
PostPosted: 18:50 - 18 May 2006    Post subject: Reply with quote
Think the server might have gone down, here's the google cache of it.
https://64.233.183.104/search?q=cache:fVamsFZhBgwJ:www.superbikeschool.com/machinery/no-bs-machine.php+&hl=en&gl=uk&ct=clnk&cd=1&client=firefox-a
Ant
PostPosted: 18:54 - 18 May 2006    Post subject: Reply with quote
it's not working for me either mate
04 ZX10R ~
veeeffarr
PostPosted: 18:58 - 18 May 2006    Post subject: Reply with quote
Click the link above Smile
tony532
PostPosted: 19:20 - 18 May 2006    Post subject: Reply with quote
the cached one works.
it's a good read cheers.
bikes owned :-
aprilia rs125 - suzuki gsxr400rrsp 1990 - yamaha yzf600r thundercat - honda hornet 6
GearboxGeezer
PostPosted: 20:04 - 18 May 2006    Post subject: Reply with quote
I still dont get countersteering, I never do it purposfully, I dont seem to get any "lag" when I steer either, but my bike is pretty light ( 125 )
Is this mainly a big bike thing or is it equally important on a 125?
greatmoorred
PostPosted: 20:12 - 18 May 2006    Post subject: Reply with quote
hmmm, i dont think i would countersteer all the time. Its fun on big swoopy corners though Smile
ram_doom
PostPosted: 20:30 - 18 May 2006    Post subject: Reply with quote
I find that countersteering combined with shifting weight forward and over the front wheel slightly works great for flicking the bike through a series of tight bends. Sort of almost feels like pulling the bike towards you. Can anyone confirm that this is perfectly acceptable technique? Mr. Green
TL1000s, KDX200
Keen
PostPosted: 20:40 - 18 May 2006    Post subject: Reply with quote
cheers toby, interesting article Thumbs Up
I consciously counter steer everytime I ride and every time I take a corner... it definately makes you feel more secure knowing that if the bend tightens up, all you have to do is shove a little harder on the inside bar Thumbs Up
SilvaRizla
PostPosted: 21:04 - 18 May 2006    Post subject: Reply with quote
Here's a question for you.....
Does shifting your weight make you counterstreer or does countersteering make you shift your weight?
I'm Ivan Dobski the Meatsafe Murderer only I never done it, I only said that I done it so they'd take the truncheon out of my bottom
Lawnie
PostPosted: 21:13 - 18 May 2006    Post subject: Reply with quote
Yeah I found that article a little confusing in parts, so I looked it up elsewhere. I get the impression that any turning above 20kph involves some degree of countersteering. So chances are you're doing it subconcsiously.
Jack_Cheese
PostPosted: 21:54 - 18 May 2006    Post subject: Reply with quote
The former for most inexperienced riders, the latter for those who have seen the light lol. I'm in with the former.
If anyone needs any more proof, stand with your bike between your legs, supporting as little of its weight with your knees as possible, then point the front wheel left. it should make your bike fall to the right.
Good read, toby Thumbs Up
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
veeeffarr
PostPosted: 00:20 - 19 May 2006    Post subject: Reply with quote
Hi,
You can counter steer without shifting your weight.
Probably a good thing to learn if you need to avoid something quickly, I do a lot of late night riding (Just got in from a sesh now) and I practice on a clear straight road at about 50/60mph swerving left to right.
I think you have to train yourself to push the bar rather than pull, and once you've done that it will make you a much safer rider.
I hit some twisties earlier (I've been active steering for a while, just never tried it on really twisty roads) and I have to say it works like an absolute dream, it's so easy to flip it from side to side and link bends in one movement.
I don't really shift my weight to be honest, I just follow what the bike wants me to do when its banked over.
But hey, I'm a n00b. Smile
Check out the video I linked at the top of my post... It's pretty damning evidence.
Caz3064
PostPosted: 09:03 - 19 May 2006    Post subject: Reply with quote
Here in Australia we have to do a counter steering manoeuvre as part of our license test, my instructor summed it up with one simple sentence, "push right, go right, push left, go left"
If you don't want to run with the big dogs...stay on the porch!
https://s72.photobucket.com/albums/i169/caz3064/YEA%20Ride%20290406/
tintin
PostPosted: 10:42 - 19 May 2006    Post subject: Reply with quote
If it makes it easier I always think of countersteering as though I am pushing DOWN on the bars, rather than forward. This gives you the impression that you are helping the bike lean down into the corner, the harder you push the more it turns.
The older I get the better I was
Dark
PostPosted: 10:58 - 19 May 2006    Post subject: Reply with quote
It can actually be quite tricky to separate your body movements from your handlebar inputs. For instance, moving from one side of the bike to the other should be done using your leg and ab muscles only whilst leaving your arms to do their job independently.
So i think its best to get counter steering down before you introduce any shifting of body weight.
fuzz
PostPosted: 13:37 - 19 May 2006    Post subject: Reply with quote
Erm...you always countersteer, it's how the bike turns. You don't think about it most of the time, but you are doing it, above 15mph or so anyway. When you don't countersteer, you go straight Wink
https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800
extreme3d
PostPosted: 13:50 - 19 May 2006    Post subject: Reply with quote
Agreed!! EVERYONE countersteer's just you don't realise it! You have to or you wouldn't lean over at all Exclamation It's something you do without realising it as the actual movements on the bars are very small - 3mm or so. It's not an advanced skill that has to be 'taught' or gained through experience, although yes once you understand how it works you can start to choose to alter how quickly you want your bike to lean over for a bend.
veeeffarr
PostPosted: 13:57 - 19 May 2006    Post subject: Reply with quote
As soon as I discovered that weight shifting did very little to move a bike, and countersteering could be controlled actively, I've never looked back, it's made biking so much more enjoyable.
Vin
PostPosted: 14:47 - 19 May 2006    Post subject: Reply with quote
I would imagine that most of us learnt to countersteer before we were 10! Remember whizzing down those hills on your pushbike?
Jack_Cheese
PostPosted: 17:53 - 19 May 2006    Post subject: Reply with quote
I've just realised why my chicken strips refuse to disappear. When right over as far as i can go, i still try and drag the bike down, rather than thinking of countersteering. I must counter steer to get it down that far, and then not realise i can't get it over any further due to the lack of further countersteering. I think i'll give it a shot consciously pushing on the bars next time i hit my favourite corners...
Jack
The last post was made 20 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.72 - MySQL Queries: 15 - Page Size: 138.84 Kb
