Home Cinema stuff
illusion
PostPosted: 22:49 - 24 May 2006    Post subject: Home Cinema stuff Reply with quote
ello,
I figure there might be some audio geeks on here that could help me out. I'm after a new home cinema amp and set of floorstanding speakers. Now, I'm just going to get 2 speakers as I am not really after the surround sound at the moment, but I figure if I go for a proper home cinema amp then it will allow me to go surround sound in the future. Mostly I am going to use it for playing music, from my PC, but also hook it up to TV/Sky/DVD.
Anyone have any suggestions on a good amp? I'd like it to be silver really, and also no more than about 200 quid. As for the speakers I'd like to keep under a 100 quid for them.
Cheers,
Dan
My bike
phantomtek
Lil Joe Tek
PostPosted: 02:28 - 25 May 2006    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=82316
What about those?
They seemed to attract a lot of interest and are within your price range Smile
Rookie
PostPosted: 02:37 - 25 May 2006    Post subject: Reply with quote
Under £100 and your floorstanders will be absolutely awful. You should either look at investing more, or go for bookshelf speakers. Mission bookshelfs can be had for under £100, or Gale.
Amplifiers - £200 is a lot, for a 2 channel amp. Here's a link to a very nice silver Marantz.
https://www.richersounds.com/showproduct.php?cda=showproduct&pid=MARA-PM4001
Unless you're looking to upgrade to surround speakers later on (in which case, the amp will cost a lot more) you needn't spend loads on an amp, it will be overkill with £100 speakers. Plus a surround sound amp has less musical quality than a 2 channel amp; I have a system where I bi-wired the speakers, then hooked the surround sound up to a surround sound amp, and then led the front 2 speakers to a 2 channel amp. Best of both worlds. Very Happy
It's like playing CDs on a DVD player. To get good results, you have to spend literally thousands (around £3000 if I remember correctly), it was the last high end TEAC DVD player that came out. In other words, try and get good 2 channel sound from a surround amp, you'll spend more than you would if you just bought 2 amps. Thumbs Up
I'd look at going £150 on the amp, £150 on the speakers. And then invest £30 in decent cables, they're the heart of the system.
Here's another link, to some half decent bookshelf speakers.
https://www.richersounds.com/showproduct.php?cda=showproduct&pid=MISS-M70S-ASST
I've got the model down from these, the Mission M70, in a surround system, and I can safely say the sound clarity will be fantastic for £70. In time though, you'll want to buy a sub woofer (£50 or so) to increase the sound depth.
https://www.richersounds.com/showproduct.php?cda=showproduct&pid=KEF-Q-COMPACT-DKAPP
Alternatively, there's a more expensive option. You could get that, and get a cheaper amp. I think you'd end up with an overall better sound. It's better to squeeze the quality out of an OK amp, rather than have a very good amp hooked up to rubbish speakers. Speakers have come along in leaps and bounds over the years, so the difference between 70s speakers and todays speakers is just huge. Whereas you can hook what was a top end amp in the 70s, up to top end speakers today, and you'd get a truly brilliant sound. Make sense? Virtually no different from todays standards, despite what manufacturers say.
If you're hooked on floorstanders, you have to spend more than you're considering. Here's a link of what I think are the cheapest you should go for:
https://www.richersounds.com/showproduct.php?cda=showproduct&pid=TDL-STUDIO10-BCH
Notice they actually have a retail of £400, that is a great deal from Richer Sounds in particular. Plus you wouldn't need a sub.
Hope that helps. Mr. Green Thumbs Up
Rookie
PostPosted: 02:39 - 25 May 2006    Post subject: Reply with quote
What about those?
Mr. Green Well look at that!
If you read the above post, you'll see I've modified the system slightly since I posted that. And now I love it so much, I cant bring myself to sell them, just yet. Embarassed
colin1
Captain Safety
PostPosted: 07:32 - 25 May 2006    Post subject: Reply with quote
richer sounds has an ebay shop where they sell off old stock.
some real bargains pop up
however, its not that rare for it to turn out to be faulty, in which case you return it to your nearest richer sounds store for a refund. so check it works the day it arrives
i got a rather nice and cheap plasma tv with a bit of screen burn (was described as such on ebay)
https://search.ebay.co.uk/_W0QQfgtpZ1QQfrppZ25QQsassZrichersoundsonline
rather than spending £30 on hifi speaker cable, get mains wiring cable from your local DIY store. This thick wiring will let current flow through much more easily than thin weedy wiring cos its so thick, and its easy to hide under the carpet.
decent interconnects between hifi components are worth getting tho
divuk83
PostPosted: 14:40 - 25 May 2006    Post subject: Reply with quote
What? You recomend decent interconnects but crap speaker cable. Thickness has nothing to do with quality. What you are paying for is the purity of the copper in the cable. You can get plenty of low profile speaker cables if thats what you need.
Dave
Rookie
PostPosted: 14:44 - 25 May 2006    Post subject: Reply with quote
Dave
Exactly. The thickness of the wire doesn't improve sound quality, it's all about how much oxygen can interrupt the flow. You can buy oxygen-free SCART cables which improves the picture on a TV. The best cables out there are the ones which are made of metals which don't pick up the interference caused by oxygen in there. The best cables in the world cost around £13,000 retail, for 10 metres. They've got an extremely high gold content.
colin1
Captain Safety
PostPosted: 14:52 - 25 May 2006    Post subject: Reply with quote
its about conductivity.
you can have a thin wire which has low impedance and has high conductivity, or you can have a very thick wire
you need a higher grade of copper to get similar conductivity in a thin cable
you can have the same conductivity in a wire of lower grade copper if its thick enough
its a similar thing with speakers
its fairly easy for a speaker with a big bass driver to make big bass, but you need expensive speakers if you want big bass out of a small box
so basically dont pay over the odds just to have things small and maintain the sound quality.
Annabella
Like a person, only smaller
PostPosted: 16:47 - 25 May 2006    Post subject: Reply with quote
I can certainly recommend the Missions. I was particularly interested in them after hearing them back to back with other equipment at the Hi Fi show. The bookshelf speakers sound far better than a number of similarlarly priced floor standing speakers - and some that are more expensive.
SCART cable has been tried by a lot of hi-fi buffs who reckon it's actually pretty damn good.
One word of advice, if you are spending a lot of money, make sure you try all of your chosen separates together before you buy them. What can sound fantastic hooked up to a mitchell gyrodeck can sound utterly shite when fed from a Pioneer CD player... Every time I have tried any kit I've made sure they use the rest of my system with it.
Avast! Pirates ahoy!
I did Cadwell! Very Happy
colin1
Captain Safety
PostPosted: 17:22 - 25 May 2006    Post subject: Reply with quote
if you limit yourself to stuff you can try out in the shop, you wont be trying last years premium stock that they are selling off at budget prices.
at this pricepoint, you get a fair indication of sound quality from comparing build quality
loook at the quality of the speaker terminals. dont go for spring clip ones
last years £300 speaker going for £150, will sound better than this years £150 speaker
ebays a good bet too, as some people like to replace their stero frequently to get the latest kit. you can then buy their old stuff for next to nothing and it will be better than what your money could buy new
the problem with bookshelf speakers is you need decent stands to get the best out of them and you might aswell spend that on floorstanders.
finally, you are thinking of spending £200 on the amp, and £100 on the speakers, I think its better to make it £150, £150, or even £100 on the amp and £200 on the speakers. Its easy to get a decent amp for not very much, but I think its worth spending a bit more on the speakers.
illusion
PostPosted: 18:16 - 25 May 2006    Post subject: Reply with quote
Thanks for all the help guys. I'm most interested in 2 channel sound for the moment i.e playing CD's and MP3's off my PC, and not too worried about DVD surround sound. In which case I'll go for a 2 channel amp if they are musically better than AV amps?
Rookie, if I wanted to add another amp later to get 5.1 you say I can do that and still use the 2 channel amp aswell? How would that work because dont you take the optical/coax output from the DVD player straight into the AV amp?
I definately want floorstanders so I'll split the budget roughly £150 for the amp and £150 for the speakers, that should do the trick. Those TDL speakers look pretty sweet, and there is a Richer Sounds not far from where I work so I'll have to nip in and have a look.
My bike
colin1
Captain Safety
PostPosted: 18:23 - 25 May 2006    Post subject: Reply with quote
if you are buying from the shop rather than online, definitly go in with some of your cds and try out a few different setups to see what you like
divuk83
PostPosted: 18:25 - 25 May 2006    Post subject: Reply with quote
If you haven't got room for floorstanders go for stand mount speakers and a sub. Do not get a cheap sub as they are slow and crap and sound awful.
Yamaha make surround amps that work with 2 channel amps. IE they just add on a centre and rear channels. I have a Dennon AV amp which is faily musical for a 5.1amp, it also allows me to plug my PC into the coax input on the amp so the PC does not process any audio.
My advice with Hi-fi stuff is to ignore hi-fi mag reviews and go our and demo the stuff and buy the kit you like the sound of. When demoing stuff take a few of your favourite CD's with you and play they same few tracks on all the kit you test so its a fair comparison and also so you can see how much better your music will sound.
Dave
Annabella
PostPosted: 18:46 - 25 May 2006    Post subject: Reply with quote
I think you should look at getting a set of Quad electro statics. Wink
https://www.hificorner.co.uk/assets/images/products/esl989.jpg
That's a window in the background by the way - You'll need a bloody massive house to fit them in first though!
illusion
PostPosted: 18:51 - 25 May 2006    Post subject: Reply with quote
Mmm, nice. Unfortunately just a 1 bed flat though Smile
My bike
nrml76
PostPosted: 22:52 - 25 May 2006    Post subject: Reply with quote
Personally, I'd get a pair of PMC's or ATC'sfor the money.
If you are looking for AV equipment, you may find this forum useful. https://www.avforums.com/forums/forumdisplay.php?f=73&page=1&sort=lastpost&order=desc&pp=25&daysprune=30
nrml76
PostPosted: 22:58 - 25 May 2006    Post subject: If Reply with quote
Dave
Sound advice indeed! The only thing I will add is that; dont let yourself be conned into buying fancy cables at outrageous prices! If you do beleive in the mystical powers of fancy cables to transform a shite setup into something extraordinay, then buy it off ebay. There are plenty of people who have seen the light, and are selling theirs off at a fraction of the cost price.
Annabella
PostPosted: 00:08 - 26 May 2006    Post subject: Reply with quote
It's about the soul... Quads have soul, like valve amps that the whole family can gather around and enjoy the warm glow from and gyrodecks with their lovely shiny oversized weights reflecting said warm glow of the valves - ahhh bliss Very Happy
If you've got the time and the inclination, you could always build your own speakers. AudioWorld (I think) the magazine has schematics and kits you can buy.
Annabella - seriously stuck in the 1970s
nrml76
PostPosted: 00:46 - 27 May 2006    Post subject: Reply with quote
I dont like the sound of vinyl or valves. It's just harmonic distortion of music. I can understand why some people like them though; fair enough. They make excellent eye candy, nothing more imo. Give me an accurate rendition of voices and instruments with accurate timing anyday!
If you are planning on building your own speakers, https://www.diyaudio.com/forums/forumdisplay.php?forumid=22 is the place to go. No better resource in the entire world! https://www.wilmslow-audio.co.uk/ are probably the best place in the UK to buy materials and parts from. They also sell some okay kits, which need almost no knowledge of speaker design to put together. Be warned! Speaker building is a highly addictive hobby!
Annabella
PostPosted: 16:06 - 30 May 2006    Post subject: Reply with quote
Except that fundamentally analogue is far more accurate than digital with no loss of high and low frequencies.
colin1
Captain Safety
PostPosted: 17:36 - 30 May 2006    Post subject: Reply with quote
analogue is better if you have expensive equipment, but digital gives good performance on ridiculously cheap equipment with no noise and is more convenient.
the sound quality of vinyl is better than cd, and the sound of cd is better than mp3 at 192k or 128k, but i have got lazy since I transferred my cds onto mp3, and now i dont even listen to cds let alone vinyl.
Rookie
PostPosted: 20:08 - 30 May 2006    Post subject: Reply with quote
That's why I'm always confused when I get MP3s at 400+kb/s. Confused It's not like they can get better quality than the CD the song originated from.
The difference between digital and analogue is simply that digital uses binary code, so every sound in the song is on/off. Whereas analogue has an infinite number of sounds between on/off. The result is a very crisp, clear sound for digital music, and a soft, fuzzier tone to analogue music. But the analogue music is more faithful to the original recording, I think. Confused
nrml76
PostPosted: 22:35 - 30 May 2006    Post subject: Reply with quote
I used to think the same, but after spending thousands of pounds on HiFi equipment over the years, I have switched to pure digital sources. My only complaints are about DAB; which is more of a broadcast issue, rather than equipment or format issue. The only analogue piece of equipment in my current setup is a Bryston amplifier. The best thing I ever did was stop reading the HiFi mags and start listening to my ears.
I am yet to listen to a deck that sounds better than a good quality CD player or transport / DAC playing a good quality, well mastered and well recorded CD (this is my personal opinion based on listening to systems at show rooms, exhibitions and friends houses, and it might differ from others). The quality issue is a myth created by manufacturers and magazines to justify extortionate prices for primitive technology.
When comparing digital and analogue media, it is imortant to compare products of similar build quality.
Digital media have a bandwith which more than exceeds the range of human hearing. Repoducing the extremes of frequency is not an issue here. Transducer technology is the more likely culprit in this situation.
Almost all the best recording studios in the world use almost entirely digital recording and playback. You would be hard pressed to find a deck there, let alone a valve amplifier; not even for playback! These are places with some of the best ears in the music industry and equipment budgets in millions of pounds. Vinyl pressings are made in very small numbers by these studios for collectors.
We could go on endlessly arguing over this, so I'll rest my case here. At the end of the day, it is what every individual likes that matters. I like clean very accurate and well timed reproduction of sound. I've found that quality digital audio works best for me.
The last post was made 20 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.5 - MySQL Queries: 13 - Page Size: 132.42 Kb
