| Author |
| davidjg |
 davidjg L Plate Warrior
| Back to top |
| kintheuk |
 kintheuk Two Stroke Sniffer
| Back to top |
| Finglonga |
 Finglonga World Chat Champion
| Back to top |
| davidjg |
 Posted: 15:52 - 04 Jun 2006 Post subject: |
thanks for that but how is it done :?any idea of a web site that covers it and tells you step by step  |
| Back to top |
| kintheuk |
 Posted: 18:04 - 04 Jun 2006 Post subject: |
If it is restricted as I thought then first off you need to remove the exhaust.
IIRC you will see the washer (?) inside the exhaust header (nearest the cylinder head) and it will be mounted to the outer edge of the exhaust at at least two points. With a flat file or maybe a hacksaw blade you should be able to remove the section of weld that holds it in place and remove the disk
If you have the blanked off KIPS valve then you just need to remove the cover and rotate the valve. It will be logically positioned at the front of the engine on the exhaust outlet.
I am fairly sure the de-restricted KMX was good for 21bhp, you are doing all of this at your own risk as the extra power will put more strain on the engine and almost certainly will reduce its life expectancy. If you are not happy to do this and worry about your own mechanical experience then don't do it.
After removing the washer and altering the valve you may need to re-jet the carb. Also there is a chance that there is a piece of rubber inserted in the space between the carb and airfilter.
I found this in the VD archive:
jjones12-Sep-2003, 19:35
newish ones there is a restricting rubber sat between the carb and airfilter. just remove it.
remove the exhaust there *may* be a washer welded in it where it leaves the head. remove it if there is.
Check this also
https://www.landrovernet.com/forum/showpost.php?p=284610&postcount=19 |
| Back to top |
| stevo as b4 |
| Back to top |
The last post was made 20 years, 69 days ago. Instead of replying here, would creating a new thread be more useful? |
