| Rob W |
 Rob W World Chat Champion
| T1z3R |
 T1z3R World Chat Champion
 Posted: 19:34 - 01 Jun 2006 Post subject: |
im not up on all the latest DDR stuff but im sure it wouldnt hurt to try it out  ____________________ duck my sick! |
| iCraig |
 iCraig World Chat Champion
| Rob W |
| edd |
 edd Nearly there...
 Posted: 21:50 - 01 Jun 2006 Post subject: |
all the ram in your system will run at the same speed. For me at least there was a huge difference moving from SD ram to DDR 400 both were a gigs worth. i dont think youll ever need 2gb of ram anyways so if i were you id take the extra slower ram out. ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
| Rob W |
| sickpup |
 sickpup Old Timer
| djr |
 djr World Chat Champion
| djr |
| Rob W |
| fuzz |
 fuzz World Chat Champion
 Posted: 11:07 - 02 Jun 2006 Post subject: |
You need to check in your BIOS. Depending on how many memory slots you have, it should show (for 4 slots) Channel A slot 0, Channel A slot 1, Channel B slot 0, Channel B slot 1. You need to put matching speed/size RAM into the same slot number, so Channel A and B slot 0 for dual channel to work.
The reason it is called dual channel is because it accesses both memory channels at the same time, so it gives 128bit access. If they are not matched, or in the same channel, the memory will be read sequentially and at only 64bit.
Like said, it is a motherboard function. The type of memory has nothing to do with it, although the pair will need to be the same size, speed and latency for it to work. That's why they are often sold as matched pairs.
| Reflex wrote: | I know that having non DC RAM in will mean the whole lot runs at 64-Bit instead of 128 |
No, all memory runs at 64bit. It is how it is accessed by the northbridge that turns it into 128bit. It's actually 2x64bit, not 1x128bit. ____________________ https://www.bikepics.com/members/fuzzbcf/
| Rob W |
| Rob W |
| fuzz |
 Posted: 11:14 - 02 Jun 2006 Post subject: |
They are sold as dual channel matched pair because they have been tested as identical. If you find two different manufactured sticks and they run at exactly the same speed and latency, they wil run in dual channel mode. Buying in matched pairs assures you that they will run in DC. Two different sticks might have a different CAS latency, for example, even though they state the same speeds.
Where the motherboard states it supports dual channel DDR, it means it can run DDR in dual channel mode, not that you can put dual channel DDR in it.
As to your question, only the DDR controller on the motherboard will utilise it. There is no other controller. ____________________ https://www.bikepics.com/members/fuzzbcf/
| Rob W |
| fuzz |
 Posted: 11:30 - 02 Jun 2006 Post subject: |
WTF has that got do with what I said?
If you read it properly, I said it runs memory in dual channel mode, you do not put dual channel memory in the slot.
On the CPU, it means it can access the memory directly. It supports dual channel mode. The memory controller usually resides in the northbridge on the motherboard. On this model it resides in the CPU. It will most likely do this automatically, but there may be a setting in the BIOS. ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
| sickpup |
 sickpup Old Timer
| lanester |
 lanester Borekit Bruiser
 Posted: 21:16 - 06 Jun 2006 Post subject: |
All the latest AMD chips have an onboard memory controler so the RAM is used more efficiently
Read this to understand that more fully (Anandtech is a good source for component info)
https://www.anandtech.com/cpuchipsets/showdoc.aspx?i=1815&p=6
Hope that helps with your on-die memory controler question |
The last post was made 20 years, 117 days ago. Instead of replying here, would creating a new thread be more useful? |
