| neeeel |
 neeeel Nova Slayer
| Bomberman |
 Bomberman World Chat Champion
 Posted: 20:02 - 28 Jun 2006 Post subject: |
As far as cooling goes, first off (assuming its second hand) the fluid could have been in it for years and therefore not that effective. Drain and replace
As to the leak you've pretty much hit the nail on the head. If you don't start pulling stuff off you'll never find it On the TZR (I have one too), if you get the fuel tank and airbox off, the engine is pretty much laid bare so you can have a good poke around (easy to do too) Grey isn't a good colour though as far as I know... Sounds like fuel and oil mix or something (although I could easily be wrong ) ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare  |
| ram_doom |
 ram_doom World Chat Champion
 Posted: 20:15 - 28 Jun 2006 Post subject: |
Oil and water mixing together it sounds like  ____________________ TL1000s, KDX200 |
| neeeel |
 neeeel Nova Slayer
| Bomberman |
 Posted: 20:55 - 28 Jun 2006 Post subject: |
Aye sorry, I meant water and oil... could also be a pointer to your cooling probs so keep an eye on your expansion tank. If its dropping, that could be it. ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
| neeeel |
 neeeel Nova Slayer
| Bomberman |
 Posted: 21:03 - 28 Jun 2006 Post subject: |
Well bearing in mind my TZR hasn't lost a drop from the expansion tank in two years I'd say that's where the extra liquid you're dripping off the bottom of the engine is coming from. Is it a grey sort of emulsion? ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
| neeeel |
 neeeel Nova Slayer
 Posted: 21:08 - 28 Jun 2006 Post subject: |
yeah thats exactly what its like.
so you think theres a leak in the pipe between the expansion tank and radiator?
or is it something more terminal than that
how can the water get mixed with oil?
thanks
neil |
| neeeel |
 neeeel Nova Slayer
| martin young |
 martin young Borekit Bruiser
| carvell |
 carvell Scuttler
| Paddy Blake |
 Paddy Blake World Chat Champion
| neeeel |
 neeeel Nova Slayer
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 21:16 - 29 Jun 2006 Post subject: |
Could it be as simple as a gasket that needs replacing? ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| martin young |
| Bomberman |
 Posted: 18:11 - 30 Jun 2006 Post subject: |
No dipstick mate, viewing window on the TZRs. neeeel, looking at the pic you posted two things spring to mind - first, is that where its leaking or just where its collecting? Secondly, isn't that very near the drain plug on the 125? ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
| neeeel |
 neeeel Nova Slayer
| martin young |
| simon1221 |
 simon1221 World Chat Champion
| Bomberman |
| flat spot |
 flat spot World Chat Champion
 Posted: 15:41 - 01 Jul 2006 Post subject: |
If it's a greyish sludgy stuff it's water mixing with oil in the gearbox. It's unlikely to be the head gasket as that would blow the top of the water reserviour.
It's likely to be the water pump seal. I don't know the tzr engine well but it's probably quite straight forward to do. Get a haynes manual.
As for water in the crank and knackering it, don't worry. The last I heard 2 strokes have a seperate gearbox and the crank is lubed by 2 stroke oil.  |
| neeeel |
 neeeel Nova Slayer
 Posted: 16:01 - 01 Jul 2006 Post subject: |
ok i had a look in the little window thats supposed to show the oil level, theres nothing in there
what is this oil for? some posts have said its transmission oil, is this right? do i need to put special oil in there, or just any engine oil.
why would it be empty anyway? to be able to mix with water leaking from the water pump , the oil must already be circulating in that area, and if it is, why doesnt it leak out of the engine casing on its own
Im hoping it is something as simple as the water pump gasket, ive ordered a new gasket , doesnt look too hard to fit. This doesnt explain my cooling problems tho. I might try to check the thermostat, and drain and clean out the radiator, and put new coolant in.
thinking back, there was one time last week where the temperature gauge was at a bout three quarters of max, and when i turned the engine off, there was a funny noise, which may have been boiling water , it sounded a bit like a rumbling belly :p
could this have blown the gasket? even before this though, the temp gauge would go up to half way really quickly
thanks for any help
neil |
| martin young |
| simon1221 |
| neeeel |
 neeeel Nova Slayer
 Posted: 23:09 - 01 Jul 2006 Post subject: |
been messing around, drained the transmission oil, which I thought was empty, but it was actually full of grey oil/water mix, which made the view window look like there wasnt a level, anyway, got most of it out started to take the casing off, and theres a bolt thats stripped and just wont move
so now i cant get into the casing. I know you can drill them out, anyone know any easier ways to move it, its not in an ideal place either, cant get a socket round it. |
The last post was made 20 years, 119 days ago. Instead of replying here, would creating a new thread be more useful? |
