| G |
 G The Voice of Reason
| Redliner |
 Redliner Spanner Monkey
 Posted: 13:05 - 04 Jul 2006 Post subject: |
The DL discs you get for £1.50 will be probably be a bit shoddy, the majority of discs are manaufactured by a small group of companies, (CMC Magnetics/Prodisc being maybe the two worst), and then rebranded and sold under various labels.
When buying discs always get either Taiyo yuden or Verbatim. They cost but they're almost always reliable burns, since Taiyo Yuden manufacture thier own discs instead of selling other peoples, and manufacture them to far higher standard than other manufacturers, and verbatim use rebranded TY or Mitsubishi (MCC) discs.
https://en.wikipedia.org/wiki/Taiyo_Yuden
https://club.cdfreaks.com/forumdisplay.php?f=33
No you can't just copy a DVD video to a DL DVD, even though you won't need transcoding to reduce the size of the DVD data, the original disc still contains copy protection that you need to bypass.
Get AnyDVD -LINK- (there's a key for this kicking round somewhere on BCF) and extract the DVD data to your HD, you can then select the DVD data on you HD in Nero, and set it to copy it to the DL DVD (make sure you select DVD9 in the appropriate part of Nero burning ROM).
Help? |
| daz|n00by |
 daz|n00by The Internet
 Posted: 13:37 - 04 Jul 2006 Post subject: |
Or for a easy way to make dual layer discs get the prog i put in this post,
https://www.bikechatforums.com/viewtopic.php?t=87848
It will make dl dvd 9 from any dvd source and also loose any restrictions you may not want  ____________________ "Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class.  |
| G |
| Mal |
 Mal Brolly Dolly
The last post was made 20 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
