can anyone help, without laughing?
tyson uk
PostPosted: 10:45 - 31 Jul 2008    Post subject: can anyone help, without laughing? Reply with quote
i have recently got a jazz 50 scooter just to nip about with, thing is the bloody thing all of a sudden isnt starting when cold, once going it runs fine but i just cannot get it to start first thing in a morning. I have put on a new choke and carb and adjusted carb setting once its going but it still wont start! any ideas please my husband and i cant think of whats wrong...
SpeedfightBoi
PostPosted: 12:45 - 31 Jul 2008    Post subject: Reply with quote
Sparkplug Confused
Try that mate
Im-a-Ridah
PostPosted: 14:57 - 31 Jul 2008    Post subject: Reply with quote
Hi there,
If it wont start at all, check the kill switch is set to run, then take the spark plug out and connect it to the lead and rest it against the metal of the bike then check if there is a spark. If there is a spark, you could try putting a small amount of fuel into the engine then refitting the spark plug and seeing if that will make it run. Remember not to overtighten the spark plug!
Also, do you know what the mileage of the bike is?
c_dug
PostPosted: 15:33 - 31 Jul 2008    Post subject: Reply with quote
Not sure of the cause of the problem but i'd advise trying some cold/easy start spray to get it going as a temporary solution...
c_dug
tyson uk
PostPosted: 15:38 - 31 Jul 2008    Post subject: Reply with quote
hi thank you for advice i have put a new spark plug in as well,it hasnt made any difference?
its only just over a year old and has just over a 1000 miles on it
Thom
PostPosted: 16:52 - 31 Jul 2008    Post subject: Reply with quote
well i was going to suggest coil going as that can cause a weak spark but normally you can start the bike ok but have poor warm running which you dont appear to?
If it's hard to start it could actually be the starter motor, i mean if fuels getting to the cyclinder, you have decent compression and a spark it should catch unless your carbs cruddy?
tyson uk
PostPosted: 18:20 - 31 Jul 2008    Post subject: Reply with quote
got decent compression once you get it to start it runs fine untill its left over night???
The last post was made 17 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.5 - MySQL Queries: 14 - Page Size: 50.23 Kb
