 Moi Derestricted Danger
 Posted: 17:05 - 25 Sep 2006 Post subject: FS - CBR1000RR5 ('05 Model) in Blue (price dropped) |
Registered May 05, Official UK model
Mileage 5050
FSH (Bradford M/C) (serviced at 4000m 4 months ago)
Running on BT014's atm (rear almost needs replacing) - new set of SuperCorsa Pro's now included in the price
Frontal Bodywork protected by armourfend/3M film - no chips or marks on bodywork that i can think off
https://homepage.ntlworld.com/kernaldb/NC30/ForSale/CBR1000RR5.jpg
https://homepage.ntlworld.com/kernaldb/NC30/ForSale/CBR1000RR5-2.jpg
sorry for the oldish pics but rest assured its not changed at all or moved much since those pics
Trick Bits
Datatool System 3 Alarm/Imob (pro fitted/certificated)
Micron Delta Can (baffled or not but BS marked even when not baffled) + std Can
PCIII USB (with Micron Delta no baffle map loaded)
Oxford Hotgrips (I can remove these if you find them embaressing)
Digigear Indicator
Light Tint DB Screen + std screen
Sato-esque Rearsets (I thought these were Sato when i bought them but theyre actually GBMoto but still run on proper bearings and work well and 100% copyright infringment on Sato's own) + std rearsets
Solo Seat (+ std pillion pad)
15:43 Gearing atm (Renthals) for extra ommph at expense of 'only' a 155mph [genuine] top speed but I will swap it back to the std 16:40 gearing if required.
Price with trick bits (& std) = £6850 incl new SuperCorsa's (loose)
Price with just std bits = £6350 incl new SuperCorsa's (loose)
or somewhere inbetween if you wish to negociate for some of the trick bits.
[email protected] or call 07977 548951 for furher details
New pictures (taken at night in the garage so they're a bit dark as my camera isn't great indoors). For proper colour guide refer to the top 2 outdoor pics.
The faint line running down from the mirror stay is the edge of the 3M protective film that adorns the front incl lights and the sides of the tank
https://homepage.ntlworld.com/kernaldb/ForSale/Front_Side.jpg
Micron (with baffle IN) and 8x6 plate which [touch wood] me or my mates have never been pulled for running however the Std sized sail is included
https://homepage.ntlworld.com/kernaldb/ForSale/RearEnd.jpg
Clocks showing milage, gear indicator and position of the Oxford heated grips control
https://homepage.ntlworld.com/kernaldb/ForSale/Clocks.jpg
The std parts + the new set of SuperCorsa Pro's
https://homepage.ntlworld.com/kernaldb/ForSale/StdParts.jpg |
