| Author |
| alan444 |
 alan444 L Plate Warrior
| Back to top |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 21:30 - 25 Sep 2006 Post subject: |
If it's going down instead of up (is 1st gear one up?) there's been a major cockup. I'm not sure how you can arrange that on a CG as there is no linkage, just a gear lever connected to an input shaft.
A racing gearbox for the CG125?!  ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| Back to top |
| hazza |
 hazza World Chat Champion
| Back to top |
| KatOwner |
 KatOwner Nova Slayer
| Back to top |
| shammon |
 shammon World Chat Champion
 Posted: 11:48 - 26 Sep 2006 Post subject: |
Problem
As above gear box has a fault , the direct shaft input to the gears is a simple set up, if it has only 4 gears then i suggest as above go back get money back. the fith gear on the cg is needed like all the rest if its missing then only worse probs are around the corner.
Q: did you check there is oil in the engine? as gears can get sticky/ difficult to engage when low or none! ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
| Back to top |
| Pete. |
 Pete. Super Spammer
| Back to top |
| Jebus |
 Jebus Brolly Dolly
 Posted: 21:01 - 27 Sep 2006 Post subject: |
You should have 1 down, thats first then a bit up is neutral and then after thats its 2nd, 3rd etc for each click. They wont be a sport box for a cg so got no idea why you got told that. Dout that you got a faulty gearbox its a cg they dont need oil or even a slight bit off attention to keep it in one piece. ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| Back to top |
There is a gap of 214 days between these two posts... |
| madmac |
 madmac L Plate Warrior
| Back to top |
| dexternotts |
 dexternotts L Plate Warrior
| Back to top |
| madmac |
| Back to top |
The last post was made 19 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
