| dransy |
 dransy World Chat Champion
| lilredmachine |
 lilredmachine World Chat Champion
| Drew |
 Drew Banned
| Kickstart |
 Kickstart The Oracle
 Posted: 13:57 - 14 Oct 2006 Post subject: |
I would be dubious about using petrol on an O ring chain, but a normal chain I doubt it would cause any problems. However it will remove all the lubricant so you would need to oil it thoroughly afterwards. And probably the best way to get oil into the rollers again would be to soak it in oil.
If a chain is coming off for a while I normally leave them to soak in a can of used engine oil.
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 13:59 - 14 Oct 2006 Post subject: |
petrol and rubber are not normally a good mix,(presuming you have a o ring chain) i would do the hard yards with oil. (any sort of oil is fine, even cooking oil ) and lube it up and try and free the sticky bits on the chain. if you have a standard chain with no orings petrol will be fine on it to clean it up initially then spend a bit of time with the oil freeing up the tight links
have fun ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| lilredmachine |
| doggone |
 doggone World Chat Champion
| mchaggis |
 mchaggis World Chat Champion
 Posted: 15:28 - 14 Oct 2006 Post subject: |
Petrol and rubber is a big no-no. A chain without o-rings in would be fine with petrol, but think of the fire risks involved too. I'd recommend paraffin as it's just as good at dissolving the crap but won't ignite given a mere hint of a spark or flame. It won't evaporate away nearly so quickly and hasn't got half the same things in it which do nasty things to your insides.
This also a reason why fuel lines are not bog standard rubber - petrol perishes it in no time. Instead you use fluoro-elastomers which will not react with petrol. Set these alight with an underbonnet fire and they release Fluorine everywhere, which leaches the Calcium from your bones.
It's not really my job to know about which elastomers are suitable for which chemicals, but it helps to know a little. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| buster |
 buster Two Stroke Sniffer
The last post was made 19 years, 359 days ago. Instead of replying here, would creating a new thread be more useful? |
