Yam SR125 pinking!
Feasty
PostPosted: 16:53 - 01 Nov 2006    Post subject: Yam SR125 pinking! Reply with quote
Hey all
my bike has been misfiring/popping for a while now, recently I've worked out it's only under stress when this happens. Accelerating, higher speeds etc.
I've filled up with a full tank of Esso Supreme plus additive and since, whilst I ride gently without harsh acceleration, the bike is smooth as anything. Especially since topping up the transmission oil! I've also noticed a bit of black spitting from the exhaust that wasn't there previously...
However, the minute I push the bike - reaching speeds of 50+ or accelerating highly, it misses and pops. Which leads me to saying the bike is definitely pinking.
My next idea is to fill up with normal unleaded and see what happens for the next few days. I have just bought a new chain and rear drum shoes which I'll be fitting over the weekend...
If it still misses and pops after all this I'm thinking of adding some Redex - in particular to the carb. I've heard spraying a fine mist of this directly into the air intake for the carb while idling can work wonders - I'll be asking round a bit more before doing this though!
Anyone any ideas what else I could do, or thoughts on what I'm thinking of doing?
All much appreciated!! Thumbs Up
Feasty
PostPosted: 17:13 - 01 Nov 2006    Post subject: Reply with quote
BLUEX5 wrote:
Strip the carb and clean all the internals untill they are surgically clean.
This has already been done about 2 weeks ago by my local shop, I've also replaced the exhaust about a month ago and checked the plug/lead all seems in pretty good working order...
Paddy Blake
PostPosted: 19:29 - 01 Nov 2006    Post subject: Reply with quote
Check the air filter
PostPosted: 21:15 - 01 Nov 2006    Post subject: Reply with quote
How old an SR125? Does it have a points ignition? Have you or anyone else attempted to 'tune' the engine to get more speed out of it?
Definately pinking and not a misfire or piston slap?
Do a plug chop at full chat and report back on the colour of the sparkplug electrode. (Put a plug spanner in your pocket, take the engine up to temperature, go for a blast at full throttle then pull the clutch in, kill the engine and come to a stop using the brakes. Whip the sparkplug out and inspect the electrode.)
Feasty
PostPosted: 10:12 - 02 Nov 2006    Post subject: Reply with quote
Thanks for all the ideas, I checked the air filter the other day and it's all nice and clean. The bike is 12 years old but I don't believe it has points ignition and I haven't touched anything to try tuning for more speed etc.
The weird thing is, last night I filled up with Jet Unleaded (not the super stuff) and the bike has been brilliant since! Last night went for a longer ride home and again later on, no problems - even got it to touch 60mph! (With my weight that is impressive lol). And again this morning, no missing/popping or anything!
I've never known different petrols to make that much difference before though I have heard some people mention it from time to time. Thing is, I'm not sure what the science is behind the improvement - any ideas?
Razz
element
PostPosted: 23:33 - 02 Nov 2006    Post subject: Reply with quote
doesnt the higher octane stuff combust at higher temp? Anyhow an sr125 wont be tuned to run on it!
Stick to the normal unleaded Wink
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
PostPosted: 15:10 - 03 Nov 2006    Post subject: Reply with quote
You wont do any harm using high octane fuel. In fact, small bikes sometimes return a sufficiently increased mpg to actually justify the cost of it.
I reckon you had some water in the bottom of the float bowls and the 'pinking' you were hearing was actually the engine misfiring.
The last post was made 19 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.56 - MySQL Queries: 14 - Page Size: 56.55 Kb
