agghhh!! urgent help needed!! bikes in bits!!
hollamat
PostPosted: 19:50 - 03 Apr 2004    Post subject: agghhh!! urgent help needed!! bikes in bits!! Reply with quote
hi
i need some mechanical guru to help me. Just took out my intake restrictor following the nsr125.com guide bu as my bike is a 125 nsr 2002 model it was slightly different anyway, took out what I think is the restrictor but it looked like a wedge shaped insert with plastic flaps on the back?? now when I rev any higher than tick over it stalls??? has any one took out the restrictor on a 2002 or later model? if so what did it look like?
please help as i'm gutted that i may have wrecked my poor baby nsr!!
cheers
ProXimaCore
Dougal
PostPosted: 19:56 - 03 Apr 2004    Post subject: Reply with quote
I found that in my NSR aswell. I belive it's actually the reed block. I was advised to quickly put it back in. Smile
Looks like you've not got a intake restrictor then. There wasn't one in mines either.
Demonic69
The Pink Rhino
PostPosted: 20:27 - 03 Apr 2004    Post subject: Reply with quote
Yes, I would advise putting it back as it could have a very detrimental effect on the running of your lil smoker Very Happy
The restrictor is "Just" a plastic/metal bit with a hole in it.
The 2002's probably just restricted in the CDi
Back on a Blade. Just feels so right.
Robby
Dirty Old Man
PostPosted: 22:05 - 03 Apr 2004    Post subject: Reply with quote
Thats the reed block. Put it back, you need it.
hollamat
PostPosted: 22:41 - 03 Apr 2004    Post subject: Reply with quote
Crying or Very sad well i've put it all back but this still leaves me with a problem!! Shocked
yesterday took me zaust off couldn't find any restriction! today stripped away at as you know around the carb and stuff again didn't find any restriction..............
but me bike only goes 85mph!! Embarassed and doesn't seem that fast off the lights Crying or Very sad maybe 11-12seconds 0-60 Embarassed not good!
where else could it be restricted as i thought uk bikes wern't restricted in the cdi.... Brick Wall anyway does anyone know anything about 2002 models regarding the cdi??
cheers
ProXimaCore
Dougal
PostPosted: 22:49 - 03 Apr 2004    Post subject: Reply with quote
My bike has the identical problem to that. No restrictors and goes to exactly 85Mph. About 11 seconds 0-60. CDI would be the only place I could think it would be restricted but my bike is also a UK bike. Confused I've never found the answer yet.
Demonic69
The Pink Rhino
PostPosted: 12:49 - 04 Apr 2004    Post subject: Reply with quote
I'm sure it's in the CDi mainly on UK models.
I think you can get one for an older NSR to fix it.
cagiva gezzer
PostPosted: 18:22 - 04 Apr 2004    Post subject: Reply with quote
That was the stuffer you removed, removing the reeds would mean it would run at all.
It could be the cdi or restrictors inside the pipe.
Search around on the euopean sites as the european bikes are restricted in different ways.
The last post was made 20 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 55.99 Kb
