CG 125 tuning
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2, 3, 4  Next
ghbrown125
PostPosted: 12:24 - 26 May 2009    Post subject: Reply with quote
it would pull that kind of gearin cos mine used to have 14 front and 41 rear, it now has 17 front and 36 rear, pull perfectly fine, if u have a racing cdi box pefrformance air filter and exhaust. Cool
Newbiker0507
PostPosted: 19:12 - 26 May 2009    Post subject: Reply with quote
https://hondacg125.awardspace.com/
Check that site, there's a good section on improving performance
honda nutter
PostPosted: 07:42 - 18 Nov 2009    Post subject: my cg Reply with quote
i ride a cg 125 03 plate when i got my bike it would not do no more then 50mph i got it in my shed every thing i didnt need went and i mean every thing i put a k&n on it only £20 put bigger carb on off a cb250 put a viper pipe on it its loud and a nice pear of bars it pulls 75mph all day long off the clock 80+ down hill hope i can be of help
unitybiker
PostPosted: 22:47 - 04 Dec 2009    Post subject: Reply with quote
CG's after the early 80's used a twin wall exhaust ,changing to a single wall non standard one and a k n N should boost 2hp just remember to adjust mixture .Although a carb swap is a good boost carbs from early 80's onwards have an accelerator pump on the side .I think the concept was ....weak mixture/jetting and richer mixture when accelerating for 11 hp traction.
I would'nt focus too much on top speed ,they just get knackerd valves and springs at top wack all day and you can quickly wear the motor out in 5,000 miles . whats special about the symetrical one cam valve timing is the amount of low down chug in 4th and 5th, by modding the exhaust and air filter they stomp along at low revs,this extra power can be geared in for 5-6mph at the higher range of use ,,,,i,e, 50 -60 mph
remember if your cg's got an enclosed chaingaurd then look after it it's a fiddly fkkkr but it will make it worth buying a decent chain because of the much longer chain life.
markrolls88
PostPosted: 22:55 - 08 Dec 2009    Post subject: cg 125 Reply with quote
i have a cg 125 mine is 2002 and mine is standard but i want more accelaration its a heavy bugger is there any where i can save weight thats simple im thin so i dont wanna lose anymore weight so it has to be the bike i can get 75 outa mine i have had 80 screaming the bollocks of going down hill with the head down as far back as i can be on the bike
sparky
johnsmith222
PostPosted: 00:16 - 09 Dec 2009    Post subject: Re: cg 125 Reply with quote
The CG is a heavy bugger?!?
Keep going the way you are at the moment and your engine will be dead in no time...
You don't need to lose weight, you need a different bike.
PostPosted: 18:39 - 10 Dec 2009    Post subject: Reply with quote
1. Put a screen on.
2. Rebump in another 6 months to make it a 6 year old thread.
Ben35
PostPosted: 22:20 - 28 Feb 2010    Post subject: Reply with quote
I put a 15/34 sprocket combo on mine (1988 BR-E engine) and it does have trouble pulling it.
But it has a lovely relaxed rpm when cruising @50mph (approx 5,500).
Down hills that baby really flies ...
Might try the slightly colder plug (9)
Ben
mrr1
PostPosted: 00:18 - 22 Mar 2010    Post subject: Reply with quote
I've got a ybr 125 as a winter hack, not a million miles away from a cg. I tried the "for more speed try two less teeth on the back sprocket" thing - what a pile of shite!!!
It took me two days to saw those bloody teeth off that cog and then the friggin' chain kept falling off!
TRX850, TDM900, ST1300, CB650SC Nighthawk, ragtop Saab, gym membership, messy divorce, large chested blonde fiance
Damn, I'm loving my midlife crisis.
mrr1
PostPosted: 00:24 - 22 Mar 2010    Post subject: Reply with quote
and then I burnt the skin on three fingers trying to araldite the bloody teeth onto the front cog!!!!
smegballs
PostPosted: 02:03 - 22 Mar 2010    Post subject: Reply with quote
I truly hope you jest!
mrr1
PostPosted: 20:37 - 26 Mar 2010    Post subject: Reply with quote
errr.....jesting, oh yes, of course - I was jesting, ha, ha
markrolls88
PostPosted: 13:54 - 05 Jun 2010    Post subject: Reply with quote
i have a 2002 cg125 i can get 75 on flat head down screaming it on the back pegs
sparky
Howling Terror
PostPosted: 14:16 - 05 Jun 2010    Post subject: Reply with quote
^^^You can get the clocks to show 75mph. Wink
Pat
Frost
PostPosted: 17:47 - 05 Jun 2010    Post subject: Reply with quote
The Shaggy D.A. wrote:
1. Put a screen on.
You sir predicted the future.
PostPosted: 19:53 - 05 Jun 2010    Post subject: Reply with quote
\o/
There is a gap of 2 years, 56 days between these two posts...
v6413
PostPosted: 12:22 - 31 Jul 2012    Post subject: Reply with quote
make sure your magnet is ok check ..for the governer and cam..within magnet....to set the point take it too a highly qualified mechanic who uses the proper equipment like "ignition timer" ,"timing light"...
talha ahmed
DMCpro
PostPosted: 13:27 - 31 Jul 2012    Post subject: Reply with quote
nice job bumping an 8 year old thread...
Honda CB-1, TS125X
VW Golf Estate
Alpha-9
PostPosted: 15:58 - 31 Jul 2012    Post subject: Re: cg 125 Reply with quote
Not as heavy as a YBR! Dance! Gagged
The bike does the speed it's designed for, you're just killing it faster with that shit
you might aswell put NOS on it and melt the whole damn engine, it's not hard
bolded the lulz
Fzr-600 1999
tahrey
PostPosted: 17:11 - 08 Oct 2012    Post subject: Reply with quote
Mild thread necromancy (on a truly ancient original post)!
I ended up at this after somehow being inspired to look at TL150s etc (I think I was looking for XR gear ratio lists or something? weird how the internet works)... a "Miller conversion"?
Has anyone actually tried some of the TL125 capacity increasing tricks and found if they also work on CGs / XRs / CRXs etc? Assuming the engines are at least vaguely related?
Seeing as I will hopefully have a bottom end to play with soon (indeed, one that NEEDS the crank taking apart to repair - in which case I can look into stroking it a little), and top ends aren't anywhere near as hard to get hold of. It's not so much of a problem if you knacker one trying to bore it out if it's not actually vital to the continued running of your everyday bike...
They don't say explicitly on the site I looked at what the stroker comes out as, just that it's "about 150cc". The additional stroke is 9.5mm, which I assume is overall (so 4.75mm additional radius, and a 4.75mm shorter rod) ... 56.5 x 49.5 goes up to 56.5 x 59.0 = 124.1cc goes up to 147.9cc.
Which is pretty good as far as I'm concerned, so long as the crank and rod adjustment work isn't too involved or expensive, the big end still has enough clearance in the block (and the rod has clearance in the casing mouth/barrel), and the gasket/pushrods/valves/carb can be adjusted to suit. Saves all the messy reboring business, is larger at the end of the day than the "146cc" big bore kit using CB550 / CB750 parts (liner and piston) plus some risky modification of the barrel, and just seems simpler and cheaper overall. And it still stays within the £16 tax band! Laughing
As well as being something different. No-one tends to make strokers any more :p
All things being equal it'd be a potential 19% torque and power increase (vs 17% for the rebore). Or an extra 2hp and 1.8NM (10.8 -> 12.8 and 9.8 -> 11.6), and probably 5mph on the top end, with hill climbing power increased by and cruising revs reduced by about 9% each (the gearing would have to be lengthened, but not by the full 19%... though this also means it could be lengthened 10-11% whilst still enjoying improved acceleration/climbing).
(IE I could likely regear it for a sustained 70 at 8500 instead of the near-9400 at present, and see a very strong 60ish cruise at a little over 7000. That would be just dandy for my purposes.)
Fuel economy might also drop 9 ~ 19%, but I somehow doubt it, given the amount of time the bike spends at full chat or very wide throttle, vs low-fractional throttle or idle - plus there's the altered gearing (124 x 9375 = 112.5k ; 148 x 8500 = 125.8k ; 125.8 / 112.5 = 111% overall airflow). It'll still use more almost certainly, but maybe more in the perfectly acceptable 5% range except when going flat-out. May even depend on jetting etc.
And of course for those just going for all out capacity on a death weapon esque project, both together would be 174cc (+40%, 15.1hp and 13.7NM, could be another 10mph there...) just with these mods, ignoring the possible 185~200cc (16~17.4hp. woo.) increases with the more exotic and risky rebores. Though one wonders why, if you were then thinking of going higher to the "theoretical 223cc maximum", you wouldn't just upgrade to an already more sophisticated 250 :p
Jamie S
PostPosted: 22:03 - 08 Oct 2012    Post subject: Reply with quote
TL125 = OHC
CG = OHV
Two very different engines.
Jamie
tahrey
PostPosted: 00:39 - 09 Oct 2012    Post subject: Reply with quote
tittyballs. of course i read the one source that says they're pushrod, and then skim the (very buried) clues on the actual tuning page that shows that they are in fact cam + chain...
all the same, would the theory hold in terms of increasing the stroke, ignoring the boring-out? given that the parts being altered aren't affected by what kind of timing system is in use? crank out, knock pin out of flywheels/counterweights, replace with (or just alter into) a slightly more offset one whilst changing the bearing on the rod... shorten the rod... tweak the effective deck height and its effect on the valve clearance... bobs yer uncle?
not that it would be at all cheap or worth the money, but it's a nice thought exercise. I'm sure someone on this board will be mad enough to eventually try it.
kramdra
PostPosted: 02:23 - 09 Oct 2012    Post subject: Reply with quote
why would you want to?
125's sound like they are about to explode. thats because they are. none of them, CG's included, are made as well as bigger engines.
wonder if you could chop a 600cc...no. CBR250RR IL4 engine in half to a 125? would be a LOT of work, if its even possible. but rev to 19k, half of 45 horses... but probably lose a few in the hackery.
Perhaps, you could just disable two cylinders, remove two pistons... remove the valve gear for them? probably be reversable.
get it tested by dvla (SVA test?) to make it leaner legal..
if thats possible, its about the same effort as tuning a shitty cg, with a lot more reward.
Teflon-Mike
tl;dr
PostPosted: 03:25 - 09 Oct 2012    Post subject: Reply with quote
Honda CB125Twin engine in full power guise offered 17bhp... bit under the 22.5 half of a CBR250R.... but close enough and not bad from a thirty five year old, two valve per cylinder air-cooled motor!
Be easier to tune one of them up, rather than cut a 250 in half and work backwards..... but, ultimately? 125 Four-Stroke? anything over 12bhp is good going, and little engine, never going to find big gains.
The last post was made 11 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.33 - MySQL Queries: 15 - Page Size: 131.53 Kb
